November 26, 2025, 11:51:15 pm
Looks good. I really like that nintendo logo in front. Is it the angle of the pic or is the plexi above the t-molding?You can always use those 2 center buttons for volume up/down.
Next time cut the tmolding slot a little higher on the cp to cover the plexi edge. And bevel the bottom of the cp so it doesn't show. I would have suggested to get a thicker tmolding but since you already beveled the plexi it might not look right. Nice build either way.
The real work of art here is that garage floor. What kind of car is that?! Very nice build. Good job.
Quote from: jmike on December 22, 2017, 04:11:26 pmNext time cut the tmolding slot a little higher on the cp to cover the plexi edge. And bevel the bottom of the cp so it doesn't show. I would have suggested to get a thicker tmolding but since you already beveled the plexi it might not look right. Nice build either way. ^ Agree - Also there really is no need for the 4 screw holes in the top to hold the plexi in place - the buttons will hold it in place fine when tightened down and it would look cleaner without the screws there !But overall a very good build !
Quote from: JDFan on December 23, 2017, 10:22:27 amQuote from: jmike on December 22, 2017, 04:11:26 pmNext time cut the tmolding slot a little higher on the cp to cover the plexi edge. And bevel the bottom of the cp so it doesn't show. I would have suggested to get a thicker tmolding but since you already beveled the plexi it might not look right. Nice build either way. ^ Agree - Also there really is no need for the 4 screw holes in the top to hold the plexi in place - the buttons will hold it in place fine when tightened down and it would look cleaner without the screws there !But overall a very good build !I disagree. If you are going to have the plexi sit above the t-molding, it's easy to snag it and lift it. If anything, the bolts need to be closer to the edge to ensure if anyone snags it, it doesn't lift up too much plexi. My experience is based on 1/8" plexi on a 26" control panel. Maybe this is thicker plexi and not anything to worry about. I turned away from plexi due to the scratches and cleaning required.
Quote from: leapinlew on December 23, 2017, 03:59:39 pmQuote from: JDFan on December 23, 2017, 10:22:27 amQuote from: jmike on December 22, 2017, 04:11:26 pmNext time cut the tmolding slot a little higher on the cp to cover the plexi edge. And bevel the bottom of the cp so it doesn't show. I would have suggested to get a thicker tmolding but since you already beveled the plexi it might not look right. Nice build either way. ^ Agree - Also there really is no need for the 4 screw holes in the top to hold the plexi in place - the buttons will hold it in place fine when tightened down and it would look cleaner without the screws there !But overall a very good build !I disagree. If you are going to have the plexi sit above the t-molding, it's easy to snag it and lift it. If anything, the bolts need to be closer to the edge to ensure if anyone snags it, it doesn't lift up too much plexi. My experience is based on 1/8" plexi on a 26" control panel. Maybe this is thicker plexi and not anything to worry about. I turned away from plexi due to the scratches and cleaning required.The screws actually secure top to base. I was thinking if using a piano hinge in back and a latch in front to secure it to base. So far the plexi hasn't snagged or lifted up in corners. It's pretty snug down. What else do you use besides plexi? I had this piece laying around so it's scratched up already and has a chip. I'm going to wind up replacing it I'm sure down the line and integrate improvements from those mentioned here.
Quote from: leapinlew on December 22, 2017, 08:00:09 pmThe real work of art here is that garage floor. What kind of car is that?! Very nice build. Good job.Pretty much what Ian said above. I had someone do it so they can prep the concrete right since I had oil stains on it from previous owner. My neighbor did the do it yourself kit and it started to peel up pretty quick. So when my guy was prepping mine and finished he went next door to see if his was still fixable. Mines 3 years going strong. Just mop it off and on to keep it clean. Oil just wipes right off. Car is a '97 Z28.
