Author Topic: Joystick wiring question  (Read 1231 times)
crapjoint
  • Last login:November 07, 2007, 08:14:20 pm
« on: February 01, 2004, 12:47:43 am »
I picked up a j-pac for my jamma cabinet and need to switch the joystick because the ones on their are 49 way.  Question is, the 49 ways are hooked up with a plug in connector.  The new ones just have terminals to connect to.  How do I know which wires go where from the original connector?
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:Joystick wiring question
« Reply #1 on: February 01, 2004, 02:34:06 am »
Since you got a J-PAC, I would assume that your controls are already connected to a JAMMA harness?  How does the 49-way interface work into your current setup?
Do you just need to know what wires from a JAMMA harness go to what controls?
crapjoint
« Reply #2 on: February 01, 2004, 10:55:03 am »
Yes, the controls are in the harness.  There are 8 wires I believe going to each joystick in a connector.  So I guess that all I need to know is what wires go to the controls from the harness.  Thanks
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #3 on: February 01, 2004, 11:59:24 am »
Ah, so you just need to know the pinout?
http://www.arcadetreasure.com/techinfo/techinfo.htm should help ya.
If you want labels to print out and attach to your harness, I know there's one at http://www.hardmvs.com/html/Downloads.htm, although it's for a Neo-Geo MVS harness pinout, so you'll have to compare it to the JAMMA pinout and make whatever changes you need to (there aren't many changes).
crapjoint
« Reply #4 on: February 03, 2004, 12:57:41 am »
This helps, although, the 3rd and 4th player are on a separate connector.  Any idea where I can get that info from?  Thanks for the help.
