Author Topic: GM .161 vs GM .179  (Read 2097 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
GM .161 vs GM .179
« on: December 14, 2017, 06:22:24 pm »
I have upgraded my GM from .161 to .179 and I am looking at my mame.ini and I have been trying to make my vertical games fit on my 27 " CRT I was trying to change my settings and I noticed the difference between my mame.ini files and I noticed that my .161 file has CRT range numbers and on my .179 mame.ini they are just set to auto . Is this correct?
buttersoft
  • Last login:Yesterday at 05:00:02 pm
  • Is running at 15kHz
Re: GM .161 vs GM .179
« Reply #1 on: December 18, 2017, 08:12:11 pm »
If it works, it's correct. If not, you need to fix it :)
Vincefaro
« Reply #2 on: December 19, 2017, 02:40:37 pm »
My Bad, I know what the difference is. They are the presets for each monitor in my case a D9800. Sorry. problem solved.
