Author Topic: Outrun project  (Read 16639 times)
redfivexw
  • Last login:March 11, 2025, 03:54:00 am
Outrun project
« on: December 10, 2017, 11:14:09 pm »
I have a sega outrun, wondering if it would be possible to hook it up to a multicart like Pandora's box.  Can outrun be wired to jamma?
redfivexw
Re: Outrun project
« Reply #1 on: December 11, 2017, 10:19:40 am »
FYI, the machine has no boards installed and i cant find a working one, which is why i am considering this route.
  • Last login:March 10, 2026, 05:35:00 am
Re: Outrun project
« Reply #2 on: December 11, 2017, 11:01:06 am »
There are Outrun PCBs on Ebay.
redfivexw
Re: Outrun project
« Reply #3 on: December 11, 2017, 12:27:27 pm »
that was so helpful, thanks!
Re: Outrun project
« Reply #4 on: December 11, 2017, 02:20:52 pm »
There aren't multicarts for the driving games because there was no set standard like JAMMA for them.
Pedals and shifters might be wired backwards from one game to the next.  Some games only had one switch in the shifter to save money.  (if you're not in low, you must be in high gear  ;)  )
So no.  No multicarts, no jamma.
You can interface the controls with a PC using an ultimarc APAC or UHID.
It takes a lot of tinkering and configuring.  It's not like a joystick cab where you can suddenly play thousands of games.
Every game in MAME needs set up individually and in the end you might end up with a couple dozen games in MAME that are playable with the controls you have.
Re: Outrun project
« Reply #5 on: December 11, 2017, 03:10:03 pm »
I can give you links if you like.
redfivexw
Re: Outrun project
« Reply #6 on: December 11, 2017, 04:49:57 pm »
Thanks Badmouth for your help
To Mike A - obviously if fixing this machine was as easy as buying a board on ebay i would not have asked for help.  This cabinet has been gutted and rather than pulling the monitor and coin door and breaking it down i am trying to make something of it, but there always has to be some person who has to give the old "what a shame" or "original is best" bull.  Sometimes it is just not economically feasible to repair them all the "right" way .  I was hoping that there might be a way to get a multiboard, set it to run one game and wire up the steering wheel, pedal and shift to jamma.  I mean, if the steering wheel is Left and Right, and the pedal is up and down, and the shift is P1 Fire, there must be a way to make it work.  I just dont know if the fact that the pedal has more or less depending on how you press it can be translated.  I just dont know enough about driving games.
smass
  • Last login:December 05, 2024, 06:12:33 pm
  • Cheapskate Arcade
Re: Outrun project
« Reply #7 on: December 11, 2017, 05:32:56 pm »
It would be a nice cab to make into a mame multi-racer.   I have a Chase HQ that I am going multi racer with, following the inspiration of this build:
http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=65327&title=chase-hq-as-mame-driving-cab
Its a bit more work that what I think you were hoping for, so trash or treasure... :)
Re: Outrun project
« Reply #8 on: December 11, 2017, 06:44:14 pm »
You specifically stated that you were exploring the multi-board route because you couldn't find an original board. I am sorry that I took you at your word.
Outrun project
« Reply #9 on: December 11, 2017, 06:51:42 pm »
I know, right? I read that too. Just say you’re not interested in restoring it, skip the lame “oh, a- I can’t find a board so I’m going to go a different route” excuse.
paigeoliver
  • Awesome face!
Re: Outrun project
« Reply #10 on: December 11, 2017, 08:42:33 pm »
Great 1000 Mile Rally is a cheap board and it will work with Out Run controls if you rewire.
Re: Outrun project
« Reply #11 on: December 11, 2017, 08:48:35 pm »
Analog controls don't work that way...
The steering wheel has a couple options 270 degree, or 360 degree and has different rates at which it can be turned, i.e. turn faster makes a sharper turn. It's not just left or right.
The shifter isn't a fire button. The game is set to tell what position the shifter is in and tells you what position it should be in. For example, in Pole position, there is low or high. Fire up Mame and you'll see how it doesn't translate to a fire button.
The pedal... well, you got that right. Usually, 50% of the way down = 50% gas, but some games treat it as a on/off (like super sprint/off road).
As soon as you can wrap your head around the different steering wheel options, combined with all the shifter (automatic, manual, various buttons like turbo), and the pedal configurations (gas, brake, shifter) you'll understand that while there may be a good deal of driving games, there aren't as many that match any 1 configuration that you may have. Or, do like me, build a cabinet and realize the amount of games your cabinet accurately plays is much less than you thought. Lastly, great arcade driving games are few and far between.
Your best bet is to put a console in it.
Re: Outrun project
« Reply #12 on: December 11, 2017, 08:51:16 pm »
Lew speaks the truth, too.
paigeoliver
  • Awesome face!
Re: Outrun project
« Reply #13 on: December 11, 2017, 10:23:11 pm »
It would help if you can define gutted? What is missing?
Re: Outrun project
« Reply #14 on: December 12, 2017, 01:10:16 pm »
See the driving cab info thread stickied in the racing subforum: http://forum.arcadecontrols.com/index.php/board,55.0.html
MAME does a good job allowing things to work with the controls you have (except that 270 degree wheels like Outrun won't work for 360 degree wheel games like Pole Position).
It's totally doable, but is a lot of work tinkering and configuring to end up with a shorter list of games than most people are expecting.
You'd probably end up with a dozen playable games in MAME.
You're initial post sounded like you were looking for a drop-in solution.
Not having experience with it, I'm guessing going the MAME PC route would take you at least a few dozen hours.
(I'm sure I spent hundreds of hours on my old driving cab, but that included a half dozen other emulators and other controls.)
So it depends on if that kind of time commitment (and cost of PC/interfaces) are worth it to you.
  • Last login:Yesterday at 08:11:32 pm
Re: Outrun project
« Reply #15 on: December 12, 2017, 01:44:13 pm »
Just burn it and move on with life.
redfivexw
Re: Outrun project
« Reply #16 on: December 12, 2017, 10:10:19 pm »
The game is missing the wiring and boards.  Someone else used it to fix theirs.  I thought maybe I could do something with it.  I think the point is missed on what I want to do, I just wanted to use a simple multi cart set for one game that could replace the original setup.  I really don't need any comments from trolls.
Re: Outrun project
« Reply #17 on: December 12, 2017, 10:29:48 pm »
Then don’t say stuff you don’t mean and act like a dick when people try to give you help. Mike wasn’t trolling you, you said....
So he tried to help you find a working one. If that was never your intent, don’t make comments like the one you did.
matsadona
Re: Outrun project
« Reply #18 on: December 13, 2017, 04:26:39 am »
If there is no wiring, why would it be more simple to put a multi-board in there rather than the original board?  ???
redfivexw
Re: Outrun project
« Reply #19 on: December 13, 2017, 07:22:56 am »
Because finding an original wiring harness and board is next to impossible, but a jamma harness and cart are easy. My only question on this post "can this be done and if so, how".  For the people with that knowledge who answered, thank you.  After re reading the post, I agree that I did not give enough info and that mike was being helpful, sorry.  I read it a different way.
« Last Edit: December 13, 2017, 07:27:49 am by redfivexw »
Re: Outrun project
« Reply #20 on: December 13, 2017, 07:40:48 am »
Well 3 seconds of searching came up with a board and a wiring harness. They come up at various prices. You just have to look. There is outrun stuff on CL too.
I just went to Ebay and searched for Outrun PCB. Sorry for the terrible pic. I am at work and I haven't had my first cup of coffee yet. I already had to modify this post a couple of times.
« Last Edit: December 13, 2017, 07:46:37 am by Mike A »
matsadona
Re: Outrun project
« Reply #21 on: December 13, 2017, 10:55:31 am »
Ok, then I understand. However if you are somewhat skilled with a soldering iron you could buy a jamma harness and have that as a base for an original board. You would need to replace the connector and a few other things of course.
By the way, is the shaker motor with all its circuitry still there, or is that gutted as well?
Please understand that most of us actually want to help, but to be honest when I read your first post I was just seconds away from nominating it for the "Troll post of the month award".  So, as always - the better input the better output you get.
Since this is one of the greatest arcade games of the 80's you would truly benefit from going that extra mile restoring it with the original board. Yes, it might be more expensive and it might not be as easy. The reward will be worth it I'm sure. Don't give up and let us help in an constructive way.
Re: Outrun project
« Reply #22 on: December 13, 2017, 03:11:08 pm »
It’s all good. Honestly, the suggestion to put a console in it is probably going to be your best bet.
paigeoliver
  • Awesome face!
Re: Outrun project
« Reply #23 on: December 13, 2017, 03:36:02 pm »
Honestly an Out Run with no boards is a parts machine anyway, there aren't really any extra boards out there.
Re: Outrun project
« Reply #24 on: December 13, 2017, 03:43:38 pm »
That's what I think as well.  I've looked into restoring one in the past and the cost of the parts ends up being a lot more than the total value of the machine.  I decided to wait and buy a complete cabinet.
Re: Outrun project
« Reply #25 on: December 13, 2017, 09:26:24 pm »
What about a multi-cart that could have all but one game disabled?!? Why aren't we talking about that option?!!
paigeoliver
  • Awesome face!
Re: Outrun project
« Reply #26 on: December 13, 2017, 09:33:03 pm »
None of them have anything appropriate on them that will interface with the controls. If you just want a one game option, then Great 1000 Mile Rally is dirt cheap and can hook up directly with the Out Run controls.
Ian
  • Last login:February 27, 2026, 11:36:05 pm
Re: Outrun project
« Reply #27 on: December 14, 2017, 10:46:50 am »
This!
It seems to me the OP doesn't want an Outrun  anyway... but a multi racer.
Re: Outrun project
« Reply #28 on: December 14, 2017, 06:55:54 pm »
sidebar:
What would it take to get mame to work on original hardware? Specifically, the shifter. I went with a return to center shifter and cycled through the gears when I needed to shift (it sucked). How could I configure it so Low and High were identified by Mame?
Re: Outrun project
« Reply #29 on: December 14, 2017, 07:35:02 pm »
Zip tie two cherry switches to it where only one at a time can be closed. Bro do you even build cabinets?
paigeoliver
  • Awesome face!
Re: Outrun project
« Reply #30 on: December 14, 2017, 08:49:11 pm »
sidebar:
You can also patch the source per game to work correctly with your shifter.
Re: Outrun project
« Reply #31 on: December 15, 2017, 09:40:48 am »
sidebar:
If using an original hi/lo shifter that stays in gear: http://forum.arcadecontrols.com/index.php/topic,135345.msg1397466.html#msg1397466
(there are other solutions in the driving cab info thread for older versions of MAME)
You might have to modify the shifter to have a switch on both hi and lo since not all games had the single switch on the same gear.
You could use the normally closed tab on the single switch, but that might become a PITA when trying to map controls.
To my knowledge there still isn't a fix (other than the default toggle) that makes MAME stay in gear after a press and release of a specific button for a gear.
This has always bugged me because most people are going to be using a PC wheel with either paddle shifters or a return to center shifter.
At least we got a fix for turning the default toggle off.
« Last Edit: December 15, 2017, 09:49:43 am by BadMouth »
nitrogen_widget
Re: Outrun project
« Reply #32 on: December 15, 2017, 01:59:08 pm »
Trow a Pi in it j/k
there is a distro called driver mame out there which simplifies driving game emulation.
Re: Outrun project
« Reply #33 on: December 15, 2017, 02:07:52 pm »
Dude hasn't logged in for days and BYOAC still flinging ---steaming pile of meadow muffin--- at him.
smass
  • Cheapskate Arcade
Re: Outrun project
« Reply #34 on: December 15, 2017, 03:11:02 pm »
Yep, it will probably end up buried in his shed for the next decade...but BYOAC still has hope!!  :cheers:
paigeoliver
  • Awesome face!
Re: Outrun project
« Reply #35 on: December 15, 2017, 09:43:39 pm »
If it is a single switch shifter you can also wire both the normally closed and the normally open terminals on it to different inputs. That will make it be triggering a different input in each position. However it makes mapping controls harder since you have to unhook the shifter to remap.
UnoWho
  • Last login:February 21, 2024, 06:36:01 pm
Re: Outrun project
« Reply #36 on: December 16, 2017, 02:40:45 am »
I think the raspberry Pi 3 is a great idea for a multi-game project.  There is a derivative game in retropie called cannonball.  This was a cool idea and should be a good starting point instead of building a Frankenstein (pronounced frankensteen) nightmare.  I have chance of a chase HQ cab for my aquarium project, and this project below is a great primer for it.
https://circuitbeard.co.uk/2017/08/28/tomy-turnin-turbo-dashboard-outrun-arcade/
redfivexw
Re: Outrun project
« Reply #37 on: December 16, 2017, 05:51:14 pm »
This!
I did not want a multi racer, just wanted a jamma solution, wanted to use a Pandora's box with all games off except outrun
« Last Edit: December 16, 2017, 05:52:59 pm by redfivexw »
redfivexw
Re: Outrun project
« Reply #38 on: December 16, 2017, 05:53:53 pm »
No, I have it right in my collection waiting for a solution
redfivexw
Re: Outrun project
« Reply #39 on: December 16, 2017, 05:55:19 pm »
It is right before xmas, I don't live here
