Author Topic: A few wiring and configuration questions  (Read 1749 times)
Shimshon816
  • Last login:November 06, 2019, 06:56:20 pm
« on: December 08, 2017, 10:56:47 am »
I've been lurking here for a while, and I've learned quite a bit. I appreciate all the advice and guidance I've gotten through eavesdropping. It inspired me to start my first build,  which I have named "The Helicarrier".
I'm ready to start connecting buttons and joysticks to an I-pac ultimate, but I'm not sure what button numbering  layout to use.
Right now, I'll mostly be using it with Retropie (A lot of A NEW, Genesis, and some MAME). Sooner or later, I'm adding a pedestal with a purpose built HTPC running Hyperspin. For any 3D games, I have Bluetooth PS3 controllers, so I'm now worried about those on the panel.
From what I've seen, the standard layout is:
123
456
With 7 buttons:
 123
 456
7
I've seen some suggestions for this:
456
123
I know I can change settings for each emulator and game, but at this stage, I want to plug the physical parts together in the way that will be the most intuitive.
Questions:
What's the best assignment for the 7 buttons on players 1 and 2?
What corresponds best to p3 and p4?
Does it make sense to piggy-back the 4-way and flight stick to p1 stick and p1 buttons 1 and 2?
Once I get it wired and start messing with the i-pac software, I'm probably going to have more questions. Thanks in advance to anyone with ideas.
P.S.: I didn't angle p3 and p4 sticks.
Sent from my SM-G935V using Tapatalk
Titchgamer
Re: A few wiring and configuration questions
« Reply #1 on: December 09, 2017, 03:55:40 am »
Ok so button layout is a personal thing everyone has different opinions but I always recommend this setup for 7 Button
567
1234
Or
1234
567
Reason being you a Standard 6 button layout but also a 4 button layout for NEO GEO.
I prefer the 1st so ime not reaching over buttons and corresponds better to Genesis controls (in my head)
Regarding the actual numbers though it makes no difference as they are completely configurable in each emu or even game in MAMEs case.
 You can piggy back sticks and buttons if you want to save inputs. I would prefer seperate though to avoid any accidental inputs from the secondary controls being knocked.
