Author Topic: Kortek KT2914F not working on high resolutions!  (Read 1778 times)
Topgun_68
  • Last login:May 28, 2022, 04:47:15 pm
« on: December 03, 2017, 05:04:20 pm »
Not sure if people still monitor these forums but wanted to know if anyone ever encountered this issue. My arcade machine worked great until I moved and now I get a blinking box that says out of range when I power it up. I removed my arcade VGA video card and hooked it directly up to the PC and it used to work at 800 x 600 or better but now the same issue. I had it repaired a few years ago so I now it had a cap kit done. I tried resetting to defaults in the hidden system menu. Is this a hardware issue with the monitor or an possible adjustment? I did manage to change the refresh rate once and got it to come up. It works fine if I hook up a standard computer monitor to it.
Thanks for any info!
George
djfender
  • Last login:April 13, 2020, 04:13:15 pm
  • I play with sega, not ladies' hearts.
Re: Kortek KT2914F not working on high resolutions!
« Reply #1 on: December 03, 2017, 06:05:42 pm »
Try a different cable?
Is that a Sanwa in your pocket or are you just happy to see me?
"Hotrodded" Hanaho Hotrod w/Kade MiniArcade 2.0 on Leonardo
