Author Topic: CRT Emudriver, Taito Type X and other pc based arcade  (Read 7697 times)
Nodoyuna
  • Last login:June 29, 2025, 10:22:15 am
« on: December 01, 2017, 07:11:05 am »
Hi
Lately, I'm in the process of getting those pc based arcade games to work... I've tried some of them and they seems to work ok, but I'd like to go a step further and try to use native resolutions and refresh rate for those games
As far as I've discovered, all Taito Type X games are 640x480@60, and Type X2 and Nesica games are 640x480@60 in low resolution mode and 1280x720 in high resolution mode...
Is this correct?
Also, what's the refresh rate for Type X2 high resolution mode?
Thanks in advance
haynor666
  • Last login:Yesterday at 05:45:00 pm
  • retro maniac
Re: CRT Emudriver, Taito Type X and other pc based arcade
« Reply #1 on: December 01, 2017, 11:33:06 am »
All games are syncing to 60 Hz. To use those games on arcade monitor/TV You have to set desktop resolution 640x480@60i. Street Fighter IV and Samurai Showdown does not look too good at 640x480. Some games like BlazeBlue does not show correctly graphics. Basically older Taito X games will be ok but Taito X2 games not too much.
All games works fine under XP. Under 7 and newer with legacy cards (Radeon HD4xxx and older) You have to use either positive sync in crt_range or Interlace Patcher (freash tool). Some of those games might still not work correctly under windows 7, more over even more does not work correctly under windows 10 (Homura and Shikigami no Shiro III are not syncing to 60 Hz anymore)
« Last Edit: December 01, 2017, 11:35:24 am by haynor666 »
Nodoyuna
« Reply #2 on: December 11, 2017, 11:52:39 am »
Hi
Thanks for the answer and sorry for my late reply...
I'm on Windows 7 and have a TV set for 15KHz games and a tube VGA monitor for 31KHz ones...
I have to note that CRT Emudriver is only installed on the VGA output, which is connected to the 15KHz TV
Taito Type X games works fine at 640x480 at 60Hz in both screens
Most Type X2 games works fine too, but some like the Blazblue ones, works for me at 30Hz, so they're slow
Other games are slow too, like KOF XII, but using D3DOverrider seems to fix those
I've seen mentioned in the forum that having the ddraw.dll file helps too, but I'm not sure of the purpose of it and it it's really needed or not...
I'm open for suggestions :D
Thanks in advance
alex2005
  • Last login:December 20, 2023, 09:21:14 am
« Reply #3 on: December 15, 2017, 03:28:33 am »
Can you play all these at full screen? for me some like blazblue and kof xiii are displaying at 16:9. They all play fine though. Im on W7 x64, asus hd 7750.
Nodoyuna
« Reply #4 on: December 15, 2017, 04:24:37 am »
Hi
They are 16:9 even on 640x480 resolution
  • Last login:Yesterday at 05:02:24 pm
« Reply #5 on: December 15, 2017, 06:43:52 am »
Hi
What video card are you using?
Nodoyuna
« Reply #6 on: December 15, 2017, 07:28:01 am »
It's an ATI Radeon R5
« Reply #7 on: December 15, 2017, 10:31:09 am »
I thought it was some HD 4xxx old card.
Anyway, this new tool might (or might not) help: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=344
kujina
  • Last login:November 04, 2021, 12:07:40 pm
« Reply #8 on: January 24, 2019, 11:07:57 am »
Windows 7 x64
Amd R9 360 2gb
CRT Emudriver 2.0 - beta 14
15khz arcade monitor
I'm currently going trough a Tetris (TGM) phase! Yesterday I got hold of 'Tetris: The Grand Master 3 Terror Instinct' which works fine. I then also download the AltInput better Input Hack which contains the files tgm3.cfg, tgm3_input.dll, demo_dump.exe and tgm3_launcher.exe.
In the tgm3.cfg file I set the resolution to 640 480 but the game's video output on screen is fuzzy and scrolling BUT if I bring up the windows Task Manager over the top of TGM3 the display is ok.
haynor666
  • retro maniac
« Reply #9 on: January 24, 2019, 01:31:54 pm »
Maybe game is forcing 60p instead of 60i.
