Author Topic: perfect settings for Vertical grovvymame with Arcade VGA 3000  (Read 2057 times)
olsch
  • Last login:December 08, 2017, 07:33:24 am
« on: November 28, 2017, 06:44:47 pm »
Hello
i search for my vertical arcade the perfect mame.ini
i hope people can help me
i use grovvymame64 0.191 with the arcade vga3000
if i  try
autoframeskip          0
frameskip                 0
seconds_to_run       0
throttle                    1
syncrefresh              1
autosync                  0
sleep                        0
speed                     1.0
refreshspeed              0
and push F11 the speed is over 100%  102% - 110%
if i try
autoframeskip             0
frameskip                    0
seconds_to_run          0
throttle                       1
syncrefresh                0
autosync                    0
sleep                          0
speed                        1.0
refreshspeed              0
i have 100% speed but tearing screen
i canot find the perfect settings for tearing free settings with 100% speed.
olsch
Re: perfect settings for Vertical grovvymame with Arcade VGA 3000
« Reply #1 on: December 02, 2017, 11:46:11 am »
i put the Arcage VGA out and put a ATI HD4670 inside with ATOM15 Bios Flash and CRT Driver 2.0.
now the speed is 100% correctly without glitches.
Calamity
  • Moderator
  • Last login:Today at 11:37:35 am
  • Quote me with care
« Reply #2 on: December 04, 2017, 04:04:27 pm »
The wrong the refresh rate in the first case was causing the speed issues.
Steps to create a log:
