Author Topic: Hyperspin rocketlauncher doesnt see roms  (Read 2633 times)
Moksi
  • Last login:December 07, 2025, 10:21:53 am
« on: November 27, 2017, 07:25:56 am »
Hello ,
ive been having a strange problem with roms being recognized in rocketlauncher for the Sega Hikaru system.
The roms are in the folder with names matching as the Database.   Also rom paths are set in HyperHQ & RocketLauncher with extension (zip)
when i scan for games only 1 gets recognized while they are all in the folder.
Help appriciated
  • Last login:Today at 01:40:55 pm
Re: Hyperspin rocketlauncher doesnt see roms
« Reply #1 on: November 27, 2017, 02:50:30 pm »
Which emulator/version are you using? (MAME, DEmul)
Do the ROM versions match the emulator version? (you might try comparing checksums)
Can you run the games from command line? (Is the emulator or rocketlauncher the problem?)
Any nag hint screens when you try to run from command line? (right now a no-nag build is not your friend)
Moksi
« Reply #2 on: November 28, 2017, 03:12:55 am »
I use Sega Demul i had it installed before i did the new fresh install, and it worked before.
I just deleted the wheel in hyperhq & removed the rocketlauncher settings.
Installed the wheel again in hyperhq & rocketlauncher setting up modules
Now i got it to recognize 4 games instead of 1.  that one being Airtrix but i dont mind that one
Maybe its possible to run that one with a command line , but going to need some help with that
