Author Topic: UltraStik 360 PC Gaming  (Read 1594 times)
Atomic666x
  • Last login:November 27, 2017, 12:02:22 pm
« on: November 26, 2017, 03:20:59 am »
I want to use my UltraStik 360 for pc gaming but I can only map it to WASD and by doing that I lose the analog feature, so instead of only moving a little bit it's full speed. Is there a program I can use that maps WASD but still keeps the sensitive move ment of analog?
SlyBlueFox
  • Last login:November 29, 2023, 12:11:50 pm
Re: UltraStik 360 PC Gaming
« Reply #1 on: November 26, 2017, 02:20:24 pm »
Assuming you are using the U360 via USB, you’ll need to use something like x360ce. This will essentially make the PC think it is a Xbox 360 controller so it’ll act like an analog joystick.
Atomic666x
« Reply #2 on: November 26, 2017, 04:00:08 pm »
Thanks I'll try it out
