Author Topic: Retro Sonic Mania (240p)  (Read 7602 times)
kortina
  • Last login:March 15, 2019, 05:06:26 am
« on: November 21, 2017, 11:54:17 pm »
Hi Guys,
Not sure if may of you have thought about using Sonic Mania in 240p, so I thought I would put together a quick demo to see what the game is like in 4:3 240p mode.
It looks stunning. I can't describe how good this plays on an old CRT with a USB Genesis/Megadrive clone controller.
Special thanks to Calamity for the drivers!!!
Titchgamer
Re: Retro Sonic Mania (240p)
« Reply #1 on: November 22, 2017, 03:17:19 am »
Cool.
I really liked sonic mania.
Its everything sonic is suposed to be to me.
I never played it on a CRT but I imagine it would be right at home.
alex2005
  • Last login:December 20, 2023, 09:21:14 am
« Reply #2 on: November 22, 2017, 04:22:21 am »
Looks amazing!
Does the game itself actually have an option to set the resolution? if yes which one did you use?
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #3 on: November 22, 2017, 05:33:29 am »
I have tested it but for me it was something like 16:9 inside the 4:3 tube - how did you change the gfx settings?
kortina
« Reply #4 on: November 22, 2017, 07:31:43 pm »
Looks amazing!
You *can* set the values in the settings.ini for the screen resolution.
However, I took the method of setting the desktop to EXACTLY what I wanted, then just launched the game in Fullscreen mode!
Less messing around.
kortina
« Reply #5 on: November 22, 2017, 07:34:01 pm »
You need to add:
pixWidth=1 into the settings.ini file
Here is the FULL detail, basically pixWidth=1 = 4:3, I think there are other values for 5:4, 16:9 but didn't bother figuring it all out when I don't need to use it.
https://steamcommunity.com/app/584400/discussions/0/1474221865177203884/
The game in 4:3 is great, the menu is a little chopped off due to 4:3 + Overscan.
keropi
« Reply #6 on: December 01, 2017, 05:12:54 pm »
just tested it - thanks for the 4:3 tip it looks great!
I couldn't get it to run in anything lower than 640x480 though
that1crzywhtguy
  • Last login:October 07, 2025, 03:36:47 pm
« Reply #7 on: December 02, 2017, 12:45:17 am »
Same here! I got it to run with my desktop on 240p, but only while Mania is windowed, so the edges get cut off. If I try to run it in 240p with fullscreen, it just crashes and closes immediately. I can get it to run in 4:3 fullscreen, but only at 640x480.
Then, once the game boots just double check in the dev menu (accessed with esc key) that it's set to a 4:3 window, and ta-da! Works great.
:) Hope this helps solve your problem.
EDIT: Aha! I just got it to work! So for my settings, in the settings.ini file, I enabled the "devmenu=1" option under game, added "pixwidth=1" under video and switched winwidth and winheight to 320 and 240 respectively.
« Last Edit: December 02, 2017, 12:55:54 am by that1crzywhtguy »
keropi
« Reply #8 on: December 02, 2017, 05:49:14 am »
thanks for the tips!
I used a batch file: changescreenresolution to 320x240 -> launch game -> change back to 640x480 once game is closed , works fine :)
m3th0d84
  • Last login:May 10, 2025, 10:31:25 am
« Reply #9 on: December 29, 2019, 11:24:26 am »
Could you share the batch file? I'm trying to do the same but without success.
keropi
« Reply #10 on: December 31, 2019, 12:29:51 pm »
sure get the zip here: https://www.mediafire.com/file/7ia1zdgucwxfd1n/launch240p.zip/file
unzip in sonicmania directory and start launch240p.bat
the batch is this:
changescreenresolution /w=320 /h=240 /d=0
SonicMania.exe
changescreenresolution /w=640 /h=480 /d=0
uses the changescreenresolution program to set 240p , launches the game then changes back resolution to 480i (assuming a crtemudriver setup with a 15k screen)
