Author Topic: Hori PS4 Stick and Crt_Emudriver  (Read 2195 times)
Heian_Shodan
« on: November 21, 2017, 09:01:22 pm »
Hello everyone, I got myself a Hori Tekken 7 PS4 Fightstick, and I'm running into an issue, I got two computers where I play arcade emulation, one through a regular pc crt with Windows 7, and another into a Sony Wega with crt_emudriver. The thing is, into my regular pc, the Hori Stick is instantly recognized as a Xbox 360 pad, while on the Crt_Emudriver pc, I get a Code 28 problem (The drivers for this device are not installed). Is this happening due to the Windows being on the Test Mode - Compilation 7601? Is there any workaround for this? If anyone can help, pls let me know  :notworthy: :notworthy: :notworthy:
Heian_Shodan
Re: Hori PS4 Stick and Crt_Emudriver
« Reply #1 on: November 22, 2017, 07:23:15 am »
So I just fixed by manually installing Xbox 360 drivers on Windows 7. If anyone else happens to go through this problem, just go to devices and printers, select the RAP.N4, right click it, Properties - Hardware - Properties - Driver and select Update Driver Software.
Go to Browse my computer for driver software, and "Let me pick from a list of device drivers on my computer". The Microsoft controller driver should be available, so you will be able to manually install it.
