Author Topic: TS2 Runtime Erros with some MODEL2 roms  (Read 2331 times)
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
« on: November 18, 2017, 08:35:58 pm »
I get this error with some Model 2 roms, i had try to disable TROUBLESHOOTER via ROCKETLAUNCHER (check box) but didnt works (but its another question)
This error create some problem during the launch of the FRONT-END, because loose the focus from the main window.
I found a extra "|" inside m2roms.lst in this selected rom (but cant solve the issue)
Test with Model 1.0 and 1.1a
« Last Edit: November 19, 2017, 08:46:14 am by Marcoqwerty »
Marcoqwerty
Re: TS2 Runtime Erros with some MODEL2 roms
« Reply #1 on: November 19, 2017, 09:02:18 am »
If i disable OUTPUT from the srally.ini of TS2
Code: [Select]
[Info]
Name=Sega Rally Pro Drivin'
WinCaption=Sega Rally Pro Drivin'
WinClass=MYWIN
ExeName=
ExePath=
LaunchGame=0
Enable=1
ExitMode=1
[Outputs]
Enable=0      <----- HERE
EmuName=Model2
NumberOutputs=4
TS2 grab correctly the roms under MAMEHOOKER (obliviously not the output)
