Author Topic: wiring a gpwiz49  (Read 1502 times)
tron84
  • Last login:November 15, 2017, 06:45:56 am
wiring a gpwiz49
« on: November 12, 2017, 01:12:03 pm »
I am a little baffled on the wiring of the GPWiz 49 to the 49 way joystick. It is a Gauntlet Legends joystick. I got the wire harness from Randy @ GGG. The harness has 10 wires but the GPWiz 49 board has 8 spots for the wires to go into?? I have the function button and the other buttons wired up fine. Here is the diagram. Thanks for any help.
http://groovygamegear.com/PDF/GPWIZ49_MAX_NEW.pdf
tron84
Re: wiring a gpwiz49
« Reply #1 on: November 12, 2017, 04:31:01 pm »
I think I found what I was looking for. The 8 go into 1-8 and the ground and +5v go into the board instead of just using the usb power and ground, that would be the 10 wires also. :cheers:
