Author Topic: MameWah as front-end for DOS MAME, lost key assignment for TAB  (Read 1947 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: November 08, 2017, 10:56:50 pm »
The TAB key used to pull up a menu within a game in MAME. The documentation says "Toggles the configuration menu."
Now the button I had set for that function does not work. When I plug in a keyboard, the TAB still does nothing. By trial and error, I found that the HOME button brings up the configuration menu (where you can enable cheats, etc.)
I use a KeyWiz Max encoder, and the one I have does not map the HOME button.
1) Is it possible that someone, while playing it, somehow accidentally re-assigned the function of the TAB key to the HOME key?
2) More importantly, how can I get it back to normal? Thanks.
Edit: had to delete "Default.cfg" in the CFG folder.
« Last Edit: November 08, 2017, 11:22:24 pm by Dougmeister »
