Author Topic: Monitor Height from Floor - guidelines?  (Read 3503 times)
bperkins01
« on: October 27, 2017, 11:34:41 am »
Hi All,
I'm in the final design stages of my cabinet - right now the design has the center of my screen at the 48.5" mark at the moment.  Looking at a few commercial cabinet designs I think I'm a bit on the low side and should maybe be at the 52-53"" level?
Can anyone recommend an ergonomics guide for this?
FWIW:  I'm 5'11"
Titchgamer
Re: Monitor Height from Floor - guidelines?
« Reply #1 on: October 27, 2017, 12:11:28 pm »
Build it so its comfortable to you as you will be playing more than anyone else.
  • Last login:Yesterday at 12:16:53 pm
« Reply #2 on: October 27, 2017, 02:14:42 pm »
Experiment.  There's no substitution for actual testing.
On an arcade cab, the angle of the screen plays a big part so there isn't a height that applies to all cab designs.
Tilted further=mounted lower
No kids playing=mount higher
Dimensions of my cab are in the thread linked in my sig, but I have no idea what the actual height of the monitor is.
It's just what felt right.
« Last Edit: October 27, 2017, 02:16:15 pm by BadMouth »
bperkins01
« Reply #3 on: October 27, 2017, 02:53:49 pm »
Thank you - I think I can mock something simple up out in the shop and see..
The universal answer to everything:  It depends   :)
I'm betting I may be a little on the low side.. for monitor height..
Titchgamer
« Reply #4 on: October 27, 2017, 03:44:35 pm »
When I built mine I first worked out the CP height by measuring
The height to my wrists when in a comfortable playing position.
Then worked out the monitor position based on having it slightly higher. Which for my angle etc worked out about 3” higher than the CP.
bperkins01
« Reply #5 on: October 27, 2017, 04:13:05 pm »
I'm certain I have a good CP height and angle..
thanks for the tips..  I'll set up things just to make sure I dont get a sore neck.
The reason I'm rethinking is that my game is Centipede..  my trackball will be about the same height..  but the center of my monitor is ~4" lower..
I'll recheck the angles.
