Author Topic: Wells Gardner K9200?  (Read 2774 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« on: October 24, 2017, 10:00:30 am »
I have the opportunity to buy this monitor and from what I can tell it's similar to the D9200 except that it is 33 inches instead of 27 inches. I can't seem to find any info on this monitor though.
Does anyone know if these are both similar or have experience with it at all? I'm mainly looking to see if the K9200 has auto resolution switching via Mame to handle CGA/EGA/VGA resolutions. My D9200 is great for this but I'd like to upgrade in size with the K9200 if they're basically the same.
  • Last login:January 26, 2026, 07:56:08 pm
Re: Wells Gardner K9200?
« Reply #1 on: October 24, 2017, 02:30:36 pm »
it should still be a D9200. the D9200 is a "series" number. the 27 you have is likely a D9204 the 33 inch version is a D9205 there is a 39" version but not much is known about it. Still likely a modded 9200.
K model analog monitors stopped with medium resolution monitors (7500 etc) and switched to the U model for analog U3000 series VGA before going to the D series digital monitors.
so unless you have some kind of frankenstein  :dunno
savj14
« Reply #2 on: October 24, 2017, 02:33:17 pm »
He said the full model number is WGM3392-UOGS21B. I'm trying to find more info anything as well. Based on the pics it's seems indentical as my D9200.
This is what the seller said about it. "WGM3392-UOGS21B. 33" 9200 series digital monitor. They were not very common, but again, if your 27" 9200 works, this should work; same boards and layout, with a few component changes. I had PNL (monitor repair company in California) convert a 33" board set to work with a 27" 9200 tube"
« Last Edit: October 24, 2017, 02:39:27 pm by savj14 »
