Author Topic: Marquee lights  (Read 1665 times)
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
Marquee lights
« on: January 30, 2004, 10:17:56 am »
Figure I can use just about any type of flourescent light for the marquee, but wanted to get feedback before I make a purchase...is there a specific wattage that works well?  Diffuser - needed or not necessary?  Any other caveats?  Also, I'm not quite ready enough to do the one-button power thing on my cab...any recommendations on a not-terribly-invasive way to turn the light on and off?  I've been looking for one that has a switch on the cord that I can just reach in the back of the cab, but haven't found one...
Now witness the power of this FULLY OPERATIONAL Mame machine!
Stingray
Re:Marquee lights
« Reply #1 on: January 30, 2004, 11:00:37 am »
No big deal to add an inline switch if that's what you're after.
-S
Ken Layton
  • Guru
  • Technician
Re:Marquee lights
« Reply #2 on: January 30, 2004, 11:17:19 am »
JAMMA standards for commercial arcade video cabinets specify the use of one F15T8CW fluorescent light. So if you go to the hardware store just get one of those 'under-the-counter' fluorescent light fixtures as they use an F15T8CW bulb (plus they are on sale alot).
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
Re:Marquee lights
« Reply #3 on: January 30, 2004, 12:28:58 pm »
just get a surge protector (power strip) and plug everything into that.  if you have a computer monitor and stuff, everything will come on at the same time by flicking the switch on the power strip.
    • GroovyGameGear.com
Re:Marquee lights
« Reply #4 on: January 30, 2004, 05:05:40 pm »
I used to try to keep the original lamp replaced in my arcade cabinet, but found that they burned out quickly, were not easy to find at a "home store" and when you could find one they were about $10 just for the tube.   :(
My take on Marquee lights is to use the cheapest thing that you feel comfortable won't burn your house down when left unattended.
Most small, under-the-counter style lights work great and usually cost only 7 or 8 dollars.  Mine's been going strong for about 1 1/2 years and on almost constantly during that time.
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
Re:Marquee lights
« Reply #5 on: January 30, 2004, 07:40:27 pm »
I use 14/15W tubes in my cabs, and they light up a marquee very nicely without them looking blown out.  If you are buying an under-the- counter style all in one unit, make sure it has a slide switch to turn the light on.  Some of those style of flo lights have a pushbutton starter where you have to hold the button in for a second or two before the light turns on.
Re:Marquee lights
« Reply #6 on: January 30, 2004, 11:18:20 pm »
Do they actually still make those?  The last time I saw that style was on a 10 year old desk lamp. :)
The two (very) cheap fixtures I bought recently have normal switches.  One "slider" and one "rocker".
But yes, that's something to watch for just in case.
OSCAR
    • Oscar Controls
Re:Marquee lights
« Reply #7 on: January 30, 2004, 11:34:20 pm »
Sure do.  Every hardware store in my town carries them, including Home Depot.  In fact, I converted two of my original cabinets over to use them, too, so all my cabs use the same bulb.  Just keeps spare parts down to a minimum.  :)
Yeah, I got some of the push&hold style fixtures over a bench in my garage.  They work just fine, but would be a pain to use in a cabinet where you don't have access to the switch.
Re:Marquee lights
« Reply #8 on: January 30, 2004, 11:42:24 pm »
Heh.  I meant the old "push and hold" style.  I think I bought one of mine at the "depot" and they were the newer "normal" switch style.
OSCAR
    • Oscar Controls
Re:Marquee lights
« Reply #9 on: January 30, 2004, 11:45:39 pm »
Ahh, I see.  I thought you were talking about the bulbs because I've heard people say before that they have had a hard time finding them.  I think Bob Roberts even has a page about converting games over to use 18" bulbs because he has trouble finding these, too.  However, apparently the Detroit area still has a large market for them because I can find them anywhere.  I can still get PBR at any party store around here, as well, so maybe we are just 10 years behind everyone else...    :D
