Author Topic: Question, Keywiz and optipac...  (Read 1040 times)
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« on: January 30, 2004, 09:52:58 am »
Do they work together.  Or do I have to have an Ipac to use the Optipac?
I have not seen this question asked yet.
I should add, I was thinking of getting me an Oscar Spinner and then a trackball to build my spinner/trackball panel.
« Last Edit: January 30, 2004, 09:54:22 am by JamesS »
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
Re:Question, Keywiz and optipac...
« Reply #1 on: January 30, 2004, 10:02:11 am »
An ipac/keywiz is for keyboard input. An optipac is for optical input. They are independant of each other.
What type of trackball are you going to use? You need to decide that before you decide to buy a optipac. I would recomend a TB with a ps2 interface and then I would tell you to buy a USB Oscar interface for your spinner. Thats just my opinion though...
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
JamesS
« Reply #2 on: January 30, 2004, 10:15:10 am »
Well I am making swappable panels, will those two work in that configuration.  I imagine I could get some extension cable for the PS2 and the USB.
crashwg
« Reply #3 on: January 30, 2004, 10:29:58 am »
I personally like that when using the optipac, only one device works at a time, so if you accidentally hit the TB when using the spinner, nothing will happen.
If you're not familiar with this feature, here's a description of how it works:
When not using either trackball (TB) or spinner (SP) the Optipac is in sortof a "standbuy" i guess you'd call it.
If you start to use the TB the SP won't work untill you stop using the TB for a given amount of time (I think it's 5 or 10 sec.)  The same goes for the reverse, If you use the SP first the TB will be rendered useless until you stop using the SP for the given amount of time.
In conclusion, I think I'm going to get the optipac, but that doesn't mean you have to (obviously).
Alot of people on this board try to discourage the purchase of the optipac saying that it is "overpriced" and you can just hack a mouse or even buy a pre-hacked mouse from somewhere, I don't remember where, but someone will chime in on that I'm sure.
Anyway, I know this post wasn't intended as a Optipac vs other method rumble, and I hope it doesn't turn into one, but I thought this information would be helpful because you don't seam to know much about the optipac (no offense if you do of course) ok, I'm done now...
Realy, that's it.
Oh yea, this is all just my opinion and I am in no way affiliated with Ultimarc :P
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
  • Last login:Yesterday at 12:49:07 am
    • GroovyGameGear.com
« Reply #4 on: January 30, 2004, 03:09:37 pm »
I can't say that I tried it, but as eightbit mentioned, they are separate interfaces.
You should be able to use the 5v out terminal of the KeyWiz to power the Optipac should you desire to do so (probably only necessary with an RS-232 serial connection).  Other than that, they wouldn't have much to do with each other.
