Author Topic: can't use specific resolution using d3d9ex  (Read 2724 times)
billfor
  • Last login:October 01, 2025, 12:07:26 pm
« on: October 07, 2017, 12:10:32 pm »
Hi, while using a d3d9ex version of gmame 186 on Windows 10, one specific resolution does not work. All of the other resolutions seem to work fine, but when I select 640x480, mame starts windowless and occupying the upper left quarter of of the screen, with no graphics, and runs out some outrageous speed (300%+). I have tried gmame -cc and various other configurations but nothing works to get the d3d9ex version working.
There is no difference in the log files between patched and unpatched versions of gmame, other than the line that indicates the d3d9 vs d3d9ex, and the crazy timing information, but I have attached but versions here anyway.
There is also a line on the console that indicates:
    Failed saving registry entry DALDTMCRTBCD640x480x0x59
but this is a system mode.
Has anyone encountered this before?
Thanks.
  • Last login:Yesterday at 10:59:40 am
Re: can't use specific resolution using d3d9ex
« Reply #1 on: October 08, 2017, 01:57:33 pm »
You probably have disabled the option lock_system_modes.
billfor
« Reply #2 on: October 09, 2017, 12:29:21 am »
Thanks. It happens with -lock_system_modes or -nolock_system_modes. It is a system resolution though.  One other thing that I noticed is with -noswitchres the d3d9ex also fails, and that is also a system resolution.
In any event, the unpatched (regular d3d) version works fine with the same configuration.  I'll try version 190 with the patch and see if that changes anything.
--- Bill
krick
  • Gotta have blue hair.
« Reply #3 on: October 09, 2017, 02:59:34 am »
Are you using Windows 7?
Make sure you have the latest DirectX installed...
https://download.microsoft.com/download/8/4/A/84A35BF1-DAFE-4AE8-82AF-AD2AE20B6B14/directx_Jun2010_redist.exe
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
billfor
« Reply #4 on: October 09, 2017, 12:18:24 pm »
It is Windows 10 x64, but I thought it came with all the older directX libraries? I tried installing the redist anyway, but it didn't help. It only fails for the system resolutions - the other gmame created resolutions work fine, and the regular d3d9 version works fine with the same config. I've tried running as Admin, setting compatibility, etc... Sometimes I just get the quarter screen in the upper left, and other times I get a more verbose message on stderr like:
SwitchRes: [tempest] (1) vertical (640x480@60.000000)->(856x480@60.000000)
Unable to create the Direct3D device (8876086C)
Unable to initialize Direct3D 9
Fatal error: Unable to complete window creation
Researching this a bit further I've seen bug reports against older versions of mame related to disabling Aero (which I have done), and missing dx libraries.  Running it with -window works actually, but then it just runs in a window which is not terribly useful  to me :-)  I've patched my v186 to change the galaxian/frogger behavior, and votrax sounds, so it is not vanilla, but I don't think those changes should affect anything. I'll build a v190 version just with d3d9ex and see if anything changes.....
[ update ] I installed the directXredist from 2010 and  built version 190 with the patch and same behavior.
« Last Edit: October 09, 2017, 11:57:13 pm by billfor »
