Author Topic: Joystick Mounting - silly question?  (Read 1482 times)
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« on: October 05, 2017, 08:38:15 am »
I suspect this is probably a silly question, but does it matter in what orientation you mount your joystick(s)
I mean, the plate is rectangular, should it sit vertical or horizontal to the CP? Does it matter?! Is there a standard anyway?!
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: Joystick Mounting - silly question?
« Reply #1 on: October 05, 2017, 09:38:19 am »
It doesn't matter, just as long as you connect the switches up correctly.
vaderag
« Reply #2 on: October 05, 2017, 10:11:09 am »
Turns out i'm pretty tight on space due to my trackball, so gonna have to go one way with P1 and a different way with p2!
