Author Topic: Anyone buy the Snes Classic?  (Read 38315 times)
  • Last login:Today at 01:01:52 am
Re: Anyone buy the Snes Classic?
« Reply #80 on: October 05, 2017, 01:29:02 pm »
I would probably have a much higher opinion of the Raspberry Pi if not for the Raspberry Pi community.
Grasshopper
« Reply #81 on: October 05, 2017, 03:47:15 pm »
This SNES variant looks like it would do the trick if you can't get ahold of a SNES at a reasonable price and want to try the Pi world.
http://www.rasptendo.com/?product=rasptendo-retro-gaming-case
Thanks for the heads up.
I'm not usually a fan of the US-styled SNES. But damn, that looks good.
I just wish I'd known about this new case a few weeks ago when I bought a Nespi case. The Nespi cases are nice but they have to be modded before the reset button will run a power down script.
From the product's set up instructions, it looks like the reset switch on this newer case will work properly out of the box.
« Reply #82 on: October 05, 2017, 03:56:47 pm »
Im going to go into all the pi threads and suggest they replace the pi with the guts from a SNES Classic.
« Reply #83 on: October 05, 2017, 04:03:56 pm »
The injection mold one here is WAY better:  https://www.amazon.com/Super-Tinytendo-Raspberry-Model-Cooling/dp/B074JJRWHH/ref=as_li_ss_tl?s=electronics&ie=UTF8&qid=1506883328&sr=1-1&keywords=tinytendo&linkCode=sl1&tag=e074d-20&linkId=fc38bb3b994abb5bc245678b4c19a1f8
DeL
Grasshopper
« Reply #84 on: October 05, 2017, 04:05:07 pm »
I downloaded a few "complete sets" and attract mode sucks balls on it.
That was your first mistake. The "complete set" images are generally a major PITA. They take forever to download, only fit on stupidly expensive SD cards, and you'll never play 99% of the games on them.
I've had much better luck with the smaller more tightly focused images. For example, I tried out MaxLittlePixel's Nintendo classic image about 6 months ago, and I've never looked back. It's only 8gb but contains pretty much every NES/SNES/Famicon game ever made.
Since then I haven't bothered with images over 8gb. They tend to be full of mostly untested shovelware, and the vast number of games makes the menus too unwieldy to navigate.
« Last Edit: October 05, 2017, 04:24:08 pm by Grasshopper »
Grasshopper
« Reply #85 on: October 05, 2017, 04:11:33 pm »
DeL
The problem with the case you linked to is that it doesn't appear to have working power and reset buttons.
vwalbridge
« Reply #86 on: October 05, 2017, 04:25:03 pm »
DeL
Just wait for RetroFlag to release their SNESPi case. Those guys know how to make a nice RPi case.
  • Last login:Today at 01:27:04 am
« Reply #87 on: October 05, 2017, 04:38:39 pm »
Yeah, I've been patiently waiting for a new Pi thread all week.   :(
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #88 on: October 05, 2017, 04:44:31 pm »
I don't plan on buying it... (yes I have a Rasberry Pi). I just hate how every company is cashing in on the nostalgic thing... Plus I can't stand Nintendo, for all of the bs they put you fan boys through... Release NES classic... run out right away, release more... run out right away, stop production (due to costs?). Release Nintendo Switch... run out of consoles, Release SNES classic... run out right away. Etc.
Nintendo has to be the worst company right now. Can't keep up with demand, keeps releasing more hardware, creates this black market of $200+ nes classics. It's freaking crazy!
Just to be clear I am not a Nintendo Fanboy, I was always more of a Genesis/Sega Cd/Dreamcast kid. I actually never owned a Nintendo product aside from the Virtual boy ahahahaha That being said I purchased this as a plug and play device that I did not have to create! Man the hours and hours I spent with Hyperspin lol But ya I HATE the black market.
Oh, I wasn't talking about you specifically... I have a lot of friends that are just die hard (to the point of being obnoxious) fanboys.
  • Last login:Today at 03:02:05 am
« Reply #89 on: October 05, 2017, 05:58:18 pm »
Retroflag does make nice NESPi cases, but you need to do a mod and install a script to send a safe shutdown command instead of just interrupting power when you press the reset button.
So far, the easiest mod for the NES case appears to be the one in by ETA PRIME.
- Bridge a few solder points (red lines)
- Solder two resistors and a wire with a female Dupont pin (yellow line) that connects to GPIO pin 5
- Install the script
Of course, if you want something easier, fully-legal and more bulletproof, a NES classic/SNES classic is the better choice.   ;D
« Reply #90 on: October 05, 2017, 06:03:58 pm »
I have the RetroFlag NesPi case and I connected mine with the default wires.  It instantly powers off and resets.  (Hard power and hard reset).  Haven't had a corrupt image yet.  I have the SD card imaged so if it does get corrupted I simply re-image it in 10 minutes.  But again, never had an issue.  For me, it's not worth the hassle to mod and add the extra shutdown script.
However, you're right, the SNES one doesn't have the power and rest.  But VWBus is right, the RetroFlag SNES case is going to be just as good and I'm sure it will include both power and reset as well once it's released.
DeL
vwalbridge
« Reply #91 on: October 05, 2017, 06:05:32 pm »
I was going to do this very mod last week but then it occurred to me that it is a somewhat pointless mod. You don't ever really have to use the Reset switch on the case. If you need to exit a game just hold start + select at the same time. And if you need to shut down the system, just use the shutdown command build into the software.
I guess if you want to show someone a neat trick, you could do this mod...but I found it to not really be worth the trouble.
DrakeTungsten
  • Last login:August 14, 2022, 06:36:45 pm
  • I effed with the wrong person!
    • No Quarter - a basic FE, WIP
« Reply #92 on: October 05, 2017, 07:05:41 pm »
That was a really helpful reply. Everybody knows you have a pi. We get it.
Wait, what's this now? I didn't know that. I must have been the lone hold-out. Now that I'm finally up to speed, you're right, he should never mention it again.
I endorse this idea. The differences between the responses you get doing that versus the responses in this thread have the potential to teach you a lesson.
I think of it as nerd magic. They can create drama out of thin air.
nitrogen_widget
« Reply #93 on: October 05, 2017, 07:52:22 pm »
Can you Pi cultists please just start your own thread? You can all congratulate each other for being intellectually superior to us commoners. Then you can leave the rest of us alone. I think all of the Pi posts belong in Politics and Religion.
tell ya what.
come to a truce, pi cultists will pull back if the guys that have a brain aneurysm every time pi is mentioned pull back also.
the main forum can be a neutral zone where pi and anti-pi unofficially comment. :)
elvis
  • penguin poker
    • StickFreaks
« Reply #94 on: October 05, 2017, 08:09:06 pm »
The greatest irony of all: the "anti-Pi-comment" comments actually outnumber the "Pi" comments by a ratio of about 10:1.  That alone is hilarious.
nitrogen_widget
« Reply #95 on: October 05, 2017, 08:13:06 pm »
so should i switch the text of my proposed armistice to the "anti-pi cult"? :)
« Reply #96 on: October 06, 2017, 01:26:51 pm »
You may not have to wait.  This one looks good and has both power and reset.
Grab it here:
https://www.argon40.com/rasptendo/rasptendo-retro-gaming-case.html
DeL
vwalbridge
« Reply #97 on: October 06, 2017, 01:35:37 pm »
Grab it here:
DeL
Not bad....and looks like the best version so far.
I'd like to hold out for the EU version. It just looked so much better than the US version.
barrymossel
  • Spectrum
« Reply #98 on: October 06, 2017, 04:28:10 pm »
Otherwise you are a really pathetic person in my opinion. Belittling people because of an opinion or preference, is just sad.[/size]
So, you're a really pathetic person since your are belittling people because of an opinion or preference?
Wow, you're an arrogant and dumb ---tallywhacker---. Were you bullied at school? You are the reason normal people don't like specialist forums.... Arrogant ---That which is odiferous and causeth plants to grow--- with no arguments (because if someone does if differently than !, it's wrong!!).
« Reply #99 on: October 06, 2017, 05:34:07 pm »
Just found this thread. Didn't realize the anti-pi and pro-pi camps were at war. I posted my Pi R2D2 build here: http://forum.arcadecontrols.com/index.php/topic,155476.msg1631425.html#msg1631425 It's a pretty sweet case that holds the controllers and cables when not playing.
My Pi takes less than 20 seconds to come up and the theme is called Comic Book. It's the best one out there (not opinion! lol)
« Reply #100 on: October 06, 2017, 06:20:04 pm »
I don’t think it’s pro-Pi vs anti-Pi so much as it’s pro-Pi vs STFU About the Pi
  • Last login:Yesterday at 05:19:21 pm
« Reply #101 on: October 06, 2017, 07:30:06 pm »
Yotsuya is exactly correct.
« Reply #102 on: October 06, 2017, 08:14:28 pm »
For example, in a thread about the SNES classic you posted about your R2D2 Pi build like it was totally on topic.
DrakeTungsten
« Reply #103 on: October 06, 2017, 08:29:31 pm »
Don't forget the don't-give-crap-but-enjoying-the-over-reaction camp.
jdbailey1206
« Reply #104 on: October 06, 2017, 08:38:29 pm »
Its pretty intense in here.  Next thing you know people will be fighting over DC vs Marvel.  Or Chevy vs Ford.  Or Yotsuya vs pbj.
« Reply #105 on: October 06, 2017, 09:01:52 pm »
Oh geez, I see Get-Off-My-Lawn Malenko is just as cheerful as ever. I'm so sure all your posts are on target.
Maybe I'm getting my streams crossed, but I thought someone said something about the Pi's taking 3 minutes to boot and having terrible front ends. I posted a pic of a cool front end and shared my experience of boot times. Seems on topic to me.  ;)
DrakeTungsten
« Reply #106 on: October 06, 2017, 09:11:58 pm »
Give the man a break. Without false equivalencies, what's he got left?
« Last Edit: October 06, 2017, 09:38:09 pm by DrakeTungsten »
  • Last login:Yesterday at 04:34:18 pm
« Reply #107 on: October 06, 2017, 09:43:43 pm »
Leapinlew, just out of curiosity, is your pi completely set-up?  Like all emulators work, with the right control configs and input-lag tuned for your LCD?
If so, may I ask how long it too you total to get it to this point?
2 big factors I can't stand the Pi.  Set-up time, and the fact the emulators are out of date. Mame especially.
« Reply #108 on: October 06, 2017, 10:26:38 pm »
Dont feed Drake Rew
« Reply #109 on: October 06, 2017, 10:38:33 pm »
It's completely setup for me.
I don't use it for mame, I'm only using it for consoles, so I avoided that whole mess. I use iPacs and PC's for my mame setups. I don't think the Pi has enough ass to deal with Mame, not to mention, I'm not sure how the setup would go. Hell, I have enough issues using an ipac and getting my game selection, button mappings, etc. to make sense.
For consoles, it works great. The only issue I had was changing an icon that displayed as Sega Master System icon instead of Sega Genesis. I'm only playing Atari 2600, NES, SNES, and Genesis on it. I only loaded the games on it that I want to play, because I'm done with scrolling through 200 games I'll never play to get to the game I want.
As for input-lag, I've experienced that only once with a modded Wii. Even if I put the TV in game mode. The Pi, with the TV I'm using, has no noticeable lag. I play Super Mario World and other precision platformers and don't see any issues.
Maybe I went into the Pi with low expectations. It's certainly got it's place. I imaged the SD card and have loaded up other Pi's. I plug it in and unplug it without shutting it down proper. I've heard they take a dump when you do that, but I haven't seen that yet.
Titchgamer
« Reply #110 on: October 07, 2017, 05:11:41 am »
I know you didnt ask me but i found the same as Lew generally.
Ive built 3 pi systems.
1) The Neo Geo bartop
2) A megadrive with MS,MS & 32x systems
3) NESpi with NES & SNES.
With the tv set to the correct AV mode no noticeable lag is present (mistake many people make with the pi)
I did have some trouble getting the controls to work correct on the megadrive pi but that was partly a problem of my own making and with a few hours of effort all sorted out.
But the NES I had built/programmed/set up & playing properly within maybe 4 hours.
05SRT4
  • Check out my Pow Pow
« Reply #111 on: October 07, 2017, 11:17:33 am »
Finally found a case for my retro pi build.....
Sent from my VS985 4G using Tapatalk
« Reply #112 on: October 07, 2017, 11:23:32 am »
DrakeTungsten
« Reply #113 on: October 07, 2017, 12:40:35 pm »
Let him who hath understanding reckon the words of Drake Tungsten: What you are seeing here, and elsewhere, is not PI vs ant-Pi. Nobody gets this emotional over a dinky piece of hardware. This has just been a band of chimps attempting to mark their territory, leaving the rest of us either confused or amused. We get that 'round these parts from time to time.
Dont feed Drake Rew
For the love of God, take this advice.  To make it easier for you: In case you're not aware, there is a handy "ignore" feature in these forums. I encourage anyone who is worried about "feeding" me to make use of it. The fewer cowards there are making straw men of my words, the more enjoyable this place will be.
« Last Edit: October 07, 2017, 02:04:48 pm by DrakeTungsten »
« Reply #114 on: October 07, 2017, 12:54:36 pm »
I once went over to the surgery ward at my local hospital and found a older gentleman waiting to get a prosthetic hip. I mentioned to him “why pay for that when you can get a pi for $35!”. He punched me in the face... I felt shame.
The end.
romshark
  • Last login:November 13, 2025, 05:36:05 pm
  • Arcade and Robotics enthusiast
« Reply #115 on: October 07, 2017, 01:31:25 pm »
Back on topic, the SNES Classic has been hacked!
Now you can add your own games to it. I haven't done it yet, but from what I heard, other games will work even if they use special chips, like the Mega Man X2 and X3 games with the C4 chip.
Also you can select options to reset to the menu using a button combination on the controller.
Here's one of the videos. Not sure if it's the most current method, but I'm sure you guys in the know can hit the usual sites for the latest hacking methods.
! No longer available
(Edit: Video embedding doesn't seem to show up for me. I think it's on my end, but just click the link anyway.)
« Last Edit: October 08, 2017, 01:25:35 am by romshark »
« Reply #116 on: October 08, 2017, 01:00:06 am »
^remove the “s” in https.
romshark
« Reply #117 on: October 08, 2017, 01:32:09 am »
Edited, but the video doesn't show up for me in the thread on either Chrome (my default browser) or Internet Explorer. Never seems to whenever someone posts a video here or on KLOV. All I see is a large blank space with "! No Longer Available" (but clicking that still takes me to the video.) Nobody else ever says anything, so it must be an issue with my computer.
*Tried it with Opera browser. It does show up there and works. Still says "! No long available" under it though. Wierd.
keilmillerjr
  • Web Developer.
« Reply #118 on: October 08, 2017, 06:36:49 am »
Same happens to me on iOS using safari. It's not just you.
« Reply #119 on: October 08, 2017, 09:47:40 am »
antiquated forum software
removing the S works in opera and firefox (on Windows)
