Author Topic: Need help to reprogram SlikStik Classic with Winipac in Windows 8.1  (Read 1371 times)
xXChartmanXx
  • Last login:September 29, 2017, 07:08:14 pm
My old PC in my arcade cabinent finally died. I bought a cheap windows 8 pc and loaded up Hyperspin and the emulators. I now need to re-program my SlikStik Classic (Which has an iPac 2 in it) to use the proper controls for Hyperspin (The version I have was pre-programmed for the emulators to all share the same controls which are not the same as a default SlikStik). The old version of Winipac that came with the SlikStik will run but cannot update the ipac (Hooked up USB). I have tried running it as Administrator and it was able to load the driver for the update but it fails saying it cannot see the controller. The controller is working and in Winipac the testmode shows all the default controller config working. I tried to load the newest version of Winipac and it would not see the iPac at all. Anyone run into this or have a workaround for programming an older iPac 2?
Thanks for any help!
Chartman
