March 04, 2026, 05:27:12 am
What's the best way to go about making the CP flush and not bolting the joysticks from the top?
Quote from: darkSSide on September 28, 2017, 04:28:40 pmWhat's the best way to go about making the CP flush and not bolting the joysticks from the top?By "making the CP flush" I assume that you mean: 1. Not having visible mounting hardware, and 2. Not having to use Bondo/wood filler to cover recessed hardware like T-nuts. (minimal surface prep)Two methods mentioned in the FAQ are "Under mount (threaded inserts)" and "Under mount (support blocks)".https://web.archive.org/web/20160809113045/http://newwiki.arcadecontrols.com/index.php?title=FAQ#JoysticksAlso check out the section on threaded inserts.Scott
Quote from: darkSSide on September 28, 2017, 04:28:40 pm 2. Not having to use Bondo/wood filler to cover recessed hardware like T-nuts. (minimal surface prep)That's what i do. T-nut countersunk on top with wood glue. I routed underneath up to the end of the t-nut. Cut bolt so i can never go beyond top of tnut. Bondo the tnut and and smooth.
Quote from: PL1 on September 28, 2017, 04:56:38 pmQuote from: darkSSide on September 28, 2017, 04:28:40 pm 2. Not having to use Bondo/wood filler to cover recessed hardware like T-nuts. (minimal surface prep)That's what i do. T-nut countersunk on top with wood glue. I routed underneath up to the end of the t-nut. Cut bolt so i can never go beyond top of tnut. Bondo the tnut and and smooth.That's what I was thinking of doing. Did you take any progression pics of your work?Sent from my Atari 2600
