Author Topic: can arcade monitors accept tv inputs?  (Read 2240 times)
crashwg
« on: January 29, 2004, 10:55:35 pm »
Is there any way that I can use an arcade monitor in my cab, and still have the ability to hook up my ps2/other systems to play DDR/other games?
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Macros
  • Last login:December 31, 2009, 07:40:44 pm
  • I want to Build My Own Arcade Controls!!
Re:can arcade monitors accept tv inputs?
« Reply #1 on: January 30, 2004, 09:30:59 am »
Out of the box this isn't possible. You need something to convert ntsc/pal to rgbs. Laserdisk games had such a pcb and you can find them on ebay pretty cheap. THis auction just ended yesterday.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=13718&item=3268975150
The other way to do this is get rgbs out of your console. THis usually reguires some soldering or obtaining the scart cable for your console. This site has more info.
http://www.gamesx.com/index2.htm
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 30, 2004, 11:08:42 am »
Wells-Gardner and some other monitor manufacturers make an accessory NTSC to RGB converter board that allows a game monitor to accept standard composite video signals such as from VCR's, video cameras, DVD players, etc.
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #3 on: February 01, 2004, 03:02:48 am »
Another option is to check out the "Super CD" from http://www.excellentcom.net/
RGB console hack may still be your best bet though.
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #4 on: February 04, 2004, 12:27:33 am »
No, they cannot accept TV inputs, but you can wire consoles to an arcade monitor with some wiring.  There are instructions to connect SNES, Saturn, Playstation, Genesis, and others to arcade monitors:
http://www.mameworld.net/pc2jamma/
darklegion
  • Last login:February 11, 2005, 11:27:02 pm
« Reply #5 on: February 09, 2004, 10:49:26 pm »
Nearly all consoles output rgb,you can either buy a scart/rgb cable and wire it up to the cab with bnc connectors or scart etc.Or you can solder directly onto the pcb for your ps2 and whatever else and make a custom connector on it,or just wire it straight up.
www.gamesx.com is good for pinouts and other info related to this
