Author Topic: Megatouch Maxx - where is the BIOS battery?  (Read 6362 times)
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
« on: September 23, 2017, 06:01:24 pm »
Have a machine I'm trying to fix with the "no date/time set, press F1 to continue error." Want to swap out the CMOS battery and set the date/time.  Here is the motherboard.  Where the hell is the battery?
  • Last login:December 04, 2025, 08:10:20 pm
Re: Megatouch Maxx - where is the BIOS battery?
« Reply #1 on: September 24, 2017, 06:26:24 pm »
bios information is stored in the realtime clock chip (RTC) it has a non-replaceable (replaceable if you are brave/skilled/stupid enough) epoxied battery inside.
new chips used to be available from maxim (DS12B887) but i don't know where besides e-bay you'd find one nowadays.
the chip number to search for is "12B887" manufactures will put all kinds of extra letters and whatnots all around it... such as your oden brand (OEC12B887A)
if you are brave enough, you can chop the outside off and remove the battery from the "core" of the chip and solder a 2032 or something to the leads. a word of caution, one end contains the battery...the other an oscillating crystal for the clock... if you damage the crystal, it will be toast. best to try and source a replacement first... then hack.
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
« Reply #2 on: September 24, 2017, 06:41:07 pm »
I might have some of those on old boards. No idea if they are still good though. I looked up the mod, and it looks pretty easy with a dremel. If they are socketed i could do the mod and send it to you. Or you could just buy the chip on ebay for $10-$20 it looks like
orizzle
« Reply #3 on: September 25, 2017, 07:44:29 am »
Thanks for the valuable info. I'll stick this in the "not worth fixing" bin
