Author Topic: NSM Digital Thunder Wall mount problem ER 30  (Read 2530 times)
Dessiemc34
  • Last login:October 30, 2017, 11:59:02 am
  • My digital thunder Jukebox needs help!
« on: September 23, 2017, 05:26:30 am »
Hi - I have a digital thunder wall mounted jukebox ( circa 1995 )
Serial number is 60003237.
The machine has functioned well for over 12 years until now. Error has came up on the screen - reading PO44 ER 30. I think a chip has gone - until I can get this chip replaced can I reprogram the jukebox to take coins again ? As it won't give me any credits for coins now , and will this memory disappear once the machine is switched off ?
Could you possibly send me the sequence to set the jukebox up for 30p one play 50p for two and four for £1 ?
Im in the Uk. I have the manual but it is not very clear. After I pull out the programme button I don't seem to be able to command the machine to remember to allot plays to money entered. It just takes the money and gives no credits.
Thanks.
ed12
Re: NSM Digital Thunder Wall mount problem ER 30
« Reply #1 on: September 23, 2017, 10:42:36 am »
programming them is very straight forward
once u are in program mode
u enter the start  mode #
what this means is the number where u expext the coin value to be 41 lets say
so u enter h key once digital should go blank
so u enter 40h after that
the left digits are the start of the page 41-47
so with a simple hit of the h key it steps through for u , and displays it
if u are not getting that far? your battery backed up dallas ram is gone (replace it)
ed
