Author Topic: Help with step 3 of CRT emudriver 2.0 HD5450 windows super resolution guide  (Read 2483 times)
slai50
  • Last login:September 04, 2017, 05:26:08 pm
I am so close to getting groovymame set up and CRT emudriver 2.0 installed but am stumped on step 3 of calamity's CRT emudriver 2.0 HD5450- windows 7-super resolution guide. From calamity's guide it says:
"STEP 3 - SETTING MAME UP
Now I have an usable 15-kHz display, but I don't have a proper mode list yet which I can use for MAME. Back to VMMaker, and click on Edit Settings.
First I'll go to the User modes tab and browse for the "user_modes - super.ini" file. This is because I want to use "super" resolutions.Then, in the MAME tab, I'm only going to browse to my GroovyMAME folder, but I won't be listing modes from XML by now. What I'll do is to check "Export settings to GroovyMAME", so future monitor settings will be synchronized with VMMaker."
So do I go to the user modes tab and choose the user mode super resolution ini and double click on it? I then exit user modes tab and go to mame tab and click on the export setting to groovymame box? Is this it or is there something more? I guess I'm confused about the part where it says browse to the groovymame folder. Do I actually need to open up the groovymame folder? Any help or clarification would be greatly appreciated, thanks.
« Last Edit: September 01, 2017, 02:06:07 am by slai50 »
silmalik
  • Last login:April 16, 2022, 09:08:13 am
    • Mednafen emu4crt mod
Re: Help with step 3 of CRT emudriver 2.0 HD5450 windows super resolution guide
« Reply #1 on: September 01, 2017, 08:14:53 am »
Hi,
In settings, you just have to select "user_modes - super.ini". Editing (double-click?) is optionnal, default should be ok.
Yes, the browse option is to inform VMMAKER where your Groovymame folder is. WMMAKER will modify the mame.ini file found there.
