February 27, 2026, 07:50:48 pm
Hi all. I have recently completed majority of the physical construction & conversion of my school desk style Taito cocktail cabinet. Woohoo! I have now moved on to the software & video display part of the project... not quite as fun as cutting up wood & using power tools, but still fun nonetheless. My set up is as follows...- WIN 98- S3 Virge GX 2 2MB AGP Video card with S-Video- Horizontally mounted 51cm/20" TVI have am running MAMEWAH, with my custom, control-panel-matching layouts working perfectly (Yay!). My problem is related to displaying vertical games on a horizontally mounted monitor. I understand this is a common problem & have done extensive searching within these forums & found the following related threads...http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=15434;start=msg120709#msg120709http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=14906;start=msg116702#msg116702http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=15271;start=msg119578#msg119578http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=14246;start=msg111389#msg111389http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=10963;start=msg85554#msg85554http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=9599;start=msg71282#msg71282http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=6579;start=msg46204#msg46204http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=4454;start=msg28189#msg28189http://www.arcadecontrols.org/yabbse/index.php?board=4;action=display;threadid=4393;start=msg27867#msg27867...but have not come across a definitive answer. Many of the above threads are people with either an arcade monitor or an ArcadeVGA, not someone with an average graphics card & a TV.Currently my cab runs horizontal games in full screen while vertical games run in what appears to be the correct proportions but are displayed significantly smaller than the vertical height of the screen. Galaga has roughly an inch & a half of black top & bottom, while Raiden is so small I was shocked. I was expecting & accepting of the black strips either side but the playable vertical area is smaller than I had anticipated. This annoys me. The other setup I tried looked great & used up the entire vertical height of the screen but surprise, surprise was cut off at the bottom. What are my options here? AdvanceMAME? PowerStrip? Is it possible to run MAME at a resolution to suit Galaga & other verticals (ie: 288) & somehow define custom resolutions for horizontal games or vice versa? Any help appreciated. BL.
