Author Topic: PS3 SCART -> VGA Adapter - > RGB  (Read 2662 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« on: August 24, 2017, 04:29:18 pm »
so anyone know of an adapter with a female scart input that has a VGA(DE-15) on the other side?
I want to use a ps3 scart cable to get RGB signal then send it through a jpac's vga port and I'm hoping to avoid sending an analog signal though an ebay SCART coupler if possible.
thanks!
mourix
  • Last login:December 02, 2025, 08:28:56 pm
Re: PS3 SCART -> VGA Adapter - > RGB
« Reply #1 on: August 25, 2017, 02:32:44 pm »
If that adapter existed, it would confuse a lot of people because it won't work on a vga monitor..
It's not too hard to solder one up, though!
voltz
  • Last login:February 14, 2018, 01:17:59 am
« Reply #2 on: August 26, 2017, 12:13:23 am »
I'm surprised you don't go the hdmi to vga route.
Btw, what is the resolution output you're planning to use?
« Last Edit: August 26, 2017, 12:20:21 am by voltz »
Moff's the Stuff!
bimm25e
« Reply #3 on: September 01, 2017, 04:24:31 pm »
Well I have a cabinet, with a 15 kHz monitor in it
I use a J-PAC  to pass a computer with CRTEmudriver through VGA to the 15khz monitor.
I want to wire in a KVM that switches audio and video going to the J-PAC between the PC and an empty Female SCART port that will take RGB from a console (modded if need be)  and shoot it to the screen through the J-PAC (video amp) and my audio amp which both go straight to the cab.
I have a female scart port but need to wire it up still, audio L/R is easy enough but what pins do I need to wire the RGB (don't care about component/composite/s-vid) video signal between the scart socket and the DB-15 (vga) pins going tinto the J-PAC?
