Author Topic: High Score Competition #224 : The King of Dragons  (Read 15042 times)
popsicle
  • Last login:Yesterday at 06:24:58 pm
« on: August 15, 2017, 09:13:04 pm »
Game Name : The King of Dragons
ROM Name  = kod (world version)
Dip Settings:
3 lives, normal (4 or 3, whichever says 'normal') difficulty, bonus life 100k and every 450k, one credit, no continues
Controls:
8 - way joystick, 2 buttons - attack and jump (both together is a special attack but uses a bit of life)
Wiki: King of Dragons
Last day: Sunday, August 27 2017, midnight Pacific Time
« Last Edit: August 21, 2017, 07:07:56 pm by popsicle »
jasonbar
  • Dr. Inferno
    • The Infernolab
Re: High Score Competition #224 : The King of Dragons
« Reply #1 on: August 17, 2017, 02:54:49 am »
Didn't we just play something like this?
Anyway, a non-bad game.
US ROM?
What DIP switch setting for the extra guys?
Disregard scores: played with 2 lives, per original top post.
Played all 5 characters 1x ea., in order from left to right.
Elf: liked him but didn't know the game. Didn't stay on the top 5. 63k or so?
Wizard: blah, no high score, no success
Fighter: much better. 99,100
Cleric: even better! 117,200
Dwarf: even betterer! 127,100.
I don't think the dwarf is truly the best. Probably Fighter or Cleric. Except for the Wizard, my score improved with each game, as I learned how to beat the bosses, what to expect, etc., so I think my scores were more of a function of me knowing what I'm doing rather than the characters being significantly better (but the Wizard was totally lame.).
-Jason
« Last Edit: August 19, 2017, 11:55:02 pm by jasonbar »
  • Last login:Today at 03:27:55 pm
« Reply #2 on: August 17, 2017, 03:54:45 am »
US ROM?
Actually, the US ROM is "kodu" -- a child ROM of "kod".
The ROM specified in OP is the parent ROM "kod" which shows up as "The King of Dragons (World 910805)" in v0.152.
Not sure if newer versions of MAME have a newer version for this parent ROM.  :dunno
acvieluf
  • Last login:February 10, 2026, 08:01:11 pm
« Reply #3 on: August 18, 2017, 07:13:49 pm »
57,900 - dwarf
Sent from my Casio keyboard
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #4 on: August 19, 2017, 10:21:32 am »
OK, I played the world version this time.
Double-checked DIPs. I played w/ 2 guys last time, so I switched to 3 guys. The scores for extra guys were lower on the world version than on the US version. Hooray.
Played elf, then fighter, then got sleepy.
232,200
-Jason
acvieluf
« Reply #5 on: August 19, 2017, 10:24:26 am »
232,200
-Jason
Glad you said so, just noticed the 3 lives thing. I was playing on 2. Argh.
acvieluf
« Reply #6 on: August 19, 2017, 10:35:53 am »
Well that makes a difference. The elf is pretty good if you can avoid damage.
125,500
popsicle
« Reply #7 on: August 19, 2017, 07:19:08 pm »
Checked my settings too, just to be sure :
World version
Difficulty 4
2 lives
Extra guy every 100k and every 450k
I had my best game ever last night - got all the way to the last boss (red dragon) and only used the wizard.
1,533,800
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #8 on: August 19, 2017, 08:08:16 pm »
Please confirm. OP says 3 lives. Latest post says 2.
Thanks,
Jason
popsicle
« Reply #9 on: August 19, 2017, 11:51:42 pm »
Yes, sorry that game was played with 2 lives setting (I pulled up the dip settings when the game ended to check). I think when I wiped my high scores and/or inadvertently entered the service mode before playing for this competition it changed?
Disregard my score in the above post. I'll play again with 3 lives setting enabled.
I've also clarified World version and bonus life settings in the original post.
lettuce
  • Make It So!
« Reply #10 on: August 20, 2017, 02:05:57 pm »
Can i confirm what difficulty we are supposed to be playing on as the default setting is '(3) Normal'????
popsicle
« Reply #11 on: August 20, 2017, 02:54:17 pm »
What? Are you running the 'world' version simply called kod? I give up. :banghead:
lettuce
  • Make It So!
« Reply #12 on: August 20, 2017, 03:16:56 pm »
Yep.
What version of MAME and Rom set are you using??
yamatetsu
  • Last login:Today at 03:39:19 pm
  • Just because.
« Reply #13 on: August 21, 2017, 05:47:46 am »
Mame .161, kod (world)
THE KING OF DRAGONS
           910805
             ETC
DIP switches :
difficulty 3 (normal)
lives 2
bonus life 200k and every 450k
popsicle
« Reply #14 on: August 21, 2017, 07:16:07 am »
-Jason
I thought my original post did say 3 lives? That's why I said to disregard my game played with 2 when it was pointed out.  :dizzy:
acvieluf
« Reply #15 on: August 21, 2017, 07:27:39 am »
I'm on mame .151, world rom "kod", difficulty is 3 (normal), and now my lives are set to 3.
yamatetsu
  • Just because.
« Reply #16 on: August 21, 2017, 09:15:14 am »
Jason and acvieluf are playing with 3 lives, I don't play the game at all, so if lettuce & popsicle also use 3 lives, everything should be golden.
I'd say that this score still is valid. Getting this with just 2 lives makes it even more impressive.
lettuce
  • Make It So!
« Reply #17 on: August 21, 2017, 02:38:57 pm »
I thought the rules were we were supposed to use the default dip settings?
Regardless though ill change the default setting from 2 to 3 lives and leave the difficulty on the default '3 (Normal)' setting
« Last Edit: August 21, 2017, 02:42:17 pm by lettuce »
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #18 on: August 21, 2017, 02:50:15 pm »
Agreed. But what MAME shows as default can vary when MAME is revved. Eek!
So, when I make a post, I search as best I can for the defaults on websites, ignoring what my old MAME rev says is default.
Search:
https://www.google.com/search?q=king+of+dragons+default+dip+switch+settings
It turns up several DIP switch tables, but only some have defaults marked:
http://www.solvalou.com/subpage/arcade_dips/T/kod
http://www.arcaderestoration.com/gamedips/9298/All/The+King+of+Dragons.aspx
These both say:
2 guys
They disagree on difficulty & free guys.
So, I propose that it's up to the OP to determine defaults as best as possible & we run with them.
Thanks,
-Jason
« Reply #19 on: August 21, 2017, 03:12:39 pm »
Best thing to do to get default dip settings is to refer to the actual arcade manual:
http://www.gallopingghostarcade.com/qr/kingofdragons/kingofdragons.pdf
I do this every time I get a new board in my collection.
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #20 on: August 21, 2017, 03:17:19 pm »
Excellent...so, is this World or US?  =O
And i don't see # of guys & scores for extra guys in the tables on p. 13 (p. 15 of PDF).
King of Dragons is hard... :banghead:
-Jason
popsicle
« Reply #21 on: August 21, 2017, 06:42:51 pm »
I'm running mame .131 and checked again to make sure I had only the 'world' kod rom in my roms folder (to make sure my front end wasn't showing a rom variation or hack). It states difficulty 4 (normal) in my dip settings. Does everyone else's say 3 is 'normal'? I wonder if the # of difficulty is the same across mame versions or is 'normal' the same?
How do you guys want to proceed? I do really like this game and would rather be discussing game play and such than this stuff, but I do agree that we need to come to a consensus.  :cheers:
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #22 on: August 21, 2017, 06:44:29 pm »
Pops-
IMO, you're the boss for this thread, so we run with what you choose for the ambiguous settings.
Thanks,
-Jason
acvieluf
« Reply #23 on: August 21, 2017, 06:55:03 pm »
Pops-
Thanks,
-Jason
Agreed
popsicle
« Reply #24 on: August 21, 2017, 07:15:46 pm »
Ok then,
I kept all of the settings in the original post, but added that it should say 'normal' difficulty, whether that is 3 or 4 for your mame version.
Onward!
And here is a run with the Elf from the other night.
890,300
I think the ranged characters (elf and mage) are way easier to play in the long haul, but harder to get started with.
acvieluf
« Reply #25 on: August 21, 2017, 09:22:12 pm »
Small improvement...argh
187,800
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #26 on: August 24, 2017, 12:11:43 pm »
Pretty forgiving game. Difficulty doesn't ramp up too quickly. Bosses aren't quarter-eaters. Doesn't get repetitive. Rather enjoyable.
368,900 with Cleric, 115u2, 3 lives, difficulty 3 (normal), 100k & 450k free guys.
-Jason
popsicle
« Reply #27 on: August 25, 2017, 12:55:39 pm »
I got to the last boss again, but just couldn't beat him. So close! I was so excited to grab my phone and take a picture I missed putting my name in :laugh:
1,404,000
popsicle
« Reply #28 on: August 25, 2017, 01:26:03 pm »
Random tips and observations
* Wizard and Elf are weak at first, but many enemies can be safely picked off from a distance. The wizard especially gets strong when he gets his lvl 5 staff.
* Food is worth a lot of points (5,000, I think) when you are already full health. This helps to level you up quickly.
* If you level up during a boss fight you can get a few quick swings in while invincible (and you get a health boost).
* Orc King - stand in his middle shadow and he can't hit you. Anticipate his jump across the screen and meet him there to land a few blows when he lands.
* Minotaur - you can hit him when standing a bit below/above when he swings his axe (missing you). Watch his charge, and run to meet him on the other side.
* Wyvern - he'll swoop from the top on the side he disappeared from. Run and jump away from him, swinging behind you when he swoops. When he flaps you away and lands, try to jump over his first fire attack and chop him from the back. He can't turn around.
* Hydra - this is really easy with range guys. Keep hitting the heads as they get knocked to the right. Watch for the swoop attack (go to another head and attack).
* Giant - time his rock throw by going up or down on the screen. I've had luck charging him, even with range characters, his fist charge hurts though, so get behind him.
* Spiders - this is a joke. Jump and swing repeatedly.
* Dragon Rider - see spiders. Jump continuously at his head, swinging away. His trident only attacks your feet.
acvieluf
« Reply #29 on: August 25, 2017, 02:13:44 pm »
Wait...so first extra life at 100k is the setting? Crap.
popsicle
« Reply #30 on: August 25, 2017, 02:34:10 pm »
acvieluf
« Reply #31 on: August 25, 2017, 02:41:44 pm »
Haha yes, I just seemed to think that it was the higher setting. My mistake...argh.
Titchgamer
« Reply #32 on: August 27, 2017, 06:46:16 am »
The bonus life settings dont seem to tie up for me :s
I have 80 & 400k or 160 & 450k
Titchgamer
« Reply #33 on: August 27, 2017, 06:54:01 am »
Fun game!
154,900
« Last Edit: August 27, 2017, 11:10:48 am by Titchgamer »
yamatetsu
  • Just because.
« Reply #34 on: August 28, 2017, 09:43:37 am »
The scoreboard.
      Click on the pic to get a larger view.
acvieluf, your turn to come up with a new exciting challenge.
« Last Edit: August 28, 2017, 11:51:15 am by yamatetsu »
acvieluf
« Reply #35 on: August 28, 2017, 09:48:57 am »
Ok, I'll put something together tonight.
acvieluf
