Author Topic: Crt emudriver for xp is not in 15khz, with my hd4800 card  (Read 2422 times)
ninjitsu12
  • Last login:March 20, 2022, 10:30:59 pm
« on: August 14, 2017, 11:51:38 am »
Hello people
I have a ati HD 4800 video card
I installed crt emudriver 9.3 for xp 32, and I changed the vmmaker.ini from custom to generic, and I installed vmmaker.exe and rebooted, so when I put the video in the arcade the image does not appear in 15khz, the split screen In 3.
I already uninstalled and installed 3 times and nothing
And in the option of the video card does not appear the option of generic15
I do not know what can be
Calamity
  • Moderator
  • Last login:February 19, 2026, 06:15:36 am
  • Quote me with care
Re: Crt emudriver for xp is not in 15khz, with my hd4800 card
« Reply #1 on: August 14, 2017, 01:12:55 pm »
VMMaker is not Soft-15kHz. You need to manually select one of the 15 kHz modes installed by VMMaker and set it as desktop resolution. This is done from the Windows screen properties dialog.
Steps to create a log:
ninjitsu12
« Reply #2 on: August 14, 2017, 01:48:19 pm »
Hi! Calamity
So I went in the properties of windows, so that does not have this option, only has HD 4800 monitor 1 and 2 and the resolution 1360x768 1024x768 and etc
And I also do not find this part that you speak
You need to manually select one of the 15 kHz modes installed by VMMaker and set it to desktop resolution
Ok now working I forgot to put the 640x480 resolution
thank you
« Last Edit: August 17, 2017, 09:17:53 pm by ninjitsu12 »
