Author Topic: Which GPU?  (Read 6158 times)
EssexMame
  • Last login:January 06, 2026, 11:26:34 am
  • Mame Weekender
Which GPU?
« on: August 07, 2017, 05:12:09 am »
First, an admission. I work in IT but I've never, ever, understood graphics cards. The numbering and constant releasing of new models means I'm clueless.
So, I need some help. I have an old PC with a decent (for the time) AMD Athlon 64 FX-60 CPU (socket 939) - the top spec and highly overclockable for that socket. However, my display has gone. I believe I need a new graphics card. Alas there is no on-board graphics to confirm this but pretty sure that's what's gone.
So, advice please - what is the best GPU to get this PC running as best it can without overspending for no improvement? It'll be for Mame/emulators to whatever it can take (N64 would be nice if it can handle it).
ark_ader
  • I glow in the dark.
Re: Which GPU?
« Reply #1 on: August 07, 2017, 07:14:25 am »
I have a 939 sitting on the shelf, and it was the decent processor at the time.  So we need to change the board and get a A6/A8/A10/A12 chip.  A general use combo would be the A8
So Ebuyer has the chip for 50 nicker
MSI A68HM-P33 V2 Socket for 30 nicker
Memory 4gb 30 nicker
As you will be using on board graphics your PSU will work, case should fit.  I did the same and got a combo deal MSI gaming mainboard and the 6350 and 2x  GTX 950 SLI with 16gb and it plays whatever I throw at it.  The A8 is a decent processor for what you want and you could get it all cheaper than 100 quid.  Just have to look.  ;D
SuperGojira2001
  • Last login:November 20, 2017, 05:14:53 pm
  • Trying to learn...
Re: Which GPU?
« Reply #2 on: August 07, 2017, 11:41:43 am »
I wouldn't bother spending money on such an old PC. If you were to build a new one what would be your budget?
EssexMame
  • Mame Weekender
Re: Which GPU?
« Reply #3 on: August 07, 2017, 11:57:42 am »
Hard to say. I didn't really think I needed a budget until now!
I'd probably need to buy a top-whack PC to move towards some PC/gaming VR. I have a crappy old desktop Dell for now for odds-n-sods and an old screen-less laptop for Mame and some older system emus.
So, next PC purchase would be to play current PC games inc. VR so top spec (but for as cheap as possible!). i.e. What we all really want :-)
ark_ader
Re: Which GPU?
« Reply #4 on: August 08, 2017, 01:43:48 am »
Well your original request was to play emulators not triple A titles and VR.  Maybe you should have been clear in your request.  ::)
EssexMame
  • Mame Weekender
Re: Which GPU?
« Reply #5 on: August 09, 2017, 11:22:29 am »
I was clear in the request. I want to get this PC running to run Mame/Emulators and therefore what GPU would be needed/possible to get it running to do so. Your information was useful, thanks.
However, if the only way was to get a new PC, that PC would be used for other purposes also (in answer to the next post from SuperGojira2001 saying to get a new PC/what is the budget).
I don't think I'd buy a new PC just for emulators. If I got a new PC I'd get the PC needed for other requirements too - make sense?
« Last Edit: August 09, 2017, 11:25:12 am by EssexMame »
  • Last login:Today at 07:56:08 pm
Re: Which GPU?
« Reply #6 on: August 09, 2017, 01:18:12 pm »
VR is a pretty tall order. I've been down the VR corridor... you need to have pretty consistent frame performance to keep from getting a case of the barfs. Video input lag gives you a "had one too many" swirly feeling when you look around. Performance is pretty key.
For instance, minimum specs for the HTC vive or Oculus Rift headsets are:
GeForce GTX 970 or AMD Radeon R9 290 or better videocard
Intel Core i5 4590 or AMD FX 8350 or greater CPU
8GB or more RAM is recommended
as always, more is better. but a minimum spec VR "capable" computer can be built for ~700 USD you could probably cut some corners by buying used video cards and whatnot. But a decent solid performance machine (self built) is in the 1000 to 1200 range.  (add another 20% for prebuilt)
(prices may vary, not all parts perform equally, consult your doctor before starting virtual reality. discontinue use if dizziness, vomiting, or anal bleeding occurs.)
Phreakwars
  • Last login:December 07, 2025, 07:04:20 pm
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
Re: Which GPU?
« Reply #7 on: August 09, 2017, 01:27:54 pm »
I wouldn't even attempt VR on a PC that old. If it's just for emulators, then an nVidia 730 GT is all I would toss into it. You can get a refurb for under $50 on newegg. I used one in my old HTPC for emulators and it did well with the exception of Dolphin playing F-Zero GX. But then, that's a pretty demanding game. other Wii titles worked ok but not great. But for MAME, ZSNES, NES, etc, etc.. it was a perfect card. Unless you are planning on playing anything more intense then that, don't waste your money on anything any more highend.
ark_ader
Re: Which GPU?
« Reply #8 on: August 09, 2017, 04:55:58 pm »
Not really.  Like I said, I had a 939 and upgraded to something I could do everything with.  I would still keep the 939 for an arcade cab, or peruse ebay for a x2 Athlon 4200 which is a beast of a chip. Get a gtx 750 for next to nothing and you are golden.  Stay away from VR, unless you have a samsung vr headset.  It is too early to invest in the technology.
EssexMame
  • Mame Weekender
Re: Which GPU?
« Reply #9 on: August 10, 2017, 05:33:37 am »
Thanks. I believe the AMD Athlon FX-60 dual core is the best done for the socket 939. Certainly, it (slightly) outranks the 4200 on https://www.cpubenchmark.net
Even if the 4200 is better it's not enough for me to need to worry about the CPU. It's 2.6Ghz dual core AMD. Not ideal for Mame which seems to prefer Intel perhaps but good enough for 80's/early 90's I'm sure.
The advice on the cheap GPU to get it running again is very useful! If I get it and my fault isn't the GPU I've not lost much (indeed I'll put it in a new PC if necessary). Seems I can get a 1Gb version for £30. Is that what I'd need?
Re: Which GPU?
« Reply #10 on: August 10, 2017, 11:12:54 am »
I've only run MAME on AMD processors.  :-)  And they work great.  Slightly better if you compile it for an AMD CPU.  Since you're in I.T. it may be right up your alley.  Check out the MAME compiler here (easy GUI interface courtesy of BYOAC member Headkaze):  http://headsoft.com.au/index.php?category=mame&page=mc64
As far as the GPU goes, you may want to look into getting a ATI Radeon card so that you have the option of running MAME on a genuine arcade monitor at 15kHz or a CRT screen.  (Any model from Radeon 7000 to the HD 7xxx family should work, both AGP and PCIe models.)  If you use an LED (and try to use 4:3) you don't really need GroovyMAME.  Read more about GroovyMAME here:  http://forum.arcadecontrols.com/index.php/topic,151459.0.html
Also, if you're curious, I'm running an AMD Phenom II X4 (quad core) on my existing MAME cab which also runs Hyperspin https://www.amazon.com/AMD-Phenom-Black-Power-Socket/dp/B001F4UV6I
Hope this info helped!
DeL
Re: Which GPU?
« Reply #11 on: August 10, 2017, 03:55:02 pm »
id be sure to get a videocard with gddr5 ram instead of gddr3. its performance will be much better for what you will get.  (still cheap but perform way better.)  a gddr5 card is somewhere around the GT500 or GT600 series mark. you should be able to get one of those for about 50 bucks.
Utderside
  • Last login:December 02, 2019, 09:25:47 pm
    • Top 15 Sex Cam Chat Sites
Re: Which GPU?
« Reply #12 on: August 13, 2017, 12:57:46 am »
VR setups for a computer usually run in the thousands for a decent one that doesn't give you any lag or stuttering. I wouldn't recommend it unless you want to budget about ~$1000+ for a good gaming rig/VR setup.
