Author Topic: Setup Xbox 360 joystick  (Read 3532 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« on: August 01, 2017, 12:33:22 pm »
Hi
i build an arcade xbox 360 for fighting games....http://jackiabu.blogspot.co.il/
now i want to play other games ...and some of them not using d'pad
can i set up only the dpad on xbox 360 stick? some xbla arcade games works only on thumbstick  :banghead:
« Last Edit: August 01, 2017, 12:40:37 pm by jackiabu »
  • Last login:February 05, 2026, 10:50:22 am
Re: Setup Xbox 360 joystick
« Reply #1 on: August 01, 2017, 12:48:30 pm »
If you hack a MadCatz Fightpad or Brawlpad instead, it has a switch that makes the D-pad act as the Left or Right analog stick.
jackiabu
« Reply #2 on: August 01, 2017, 02:20:56 pm »
thanks, but i don't have any of this option available :-\ other idea?
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #3 on: August 01, 2017, 03:26:07 pm »
If you are talking about on the 360 and not the pc, you HAVE to get a gamepad or encoder board that has the analog stick inputs to use them..... you don't have any other option.  Hack a cheap knock-off pad if money is the issue.
That being said, games that don't use the d-pad are probably games that need analog inputs, so they aren't going to be fun to play on a digital joystick anyway.
jackiabu
« Reply #4 on: August 01, 2017, 03:47:31 pm »
OK i give up . i stick only with this type of games :-......
