Author Topic: Monitor Identification Help - Wells Gardner D9800 [IDENTIFIED]  (Read 29040 times)
krick
  • Gotta have blue hair.
A user in the GroovyMAME forum posted some pictures of his monitor and we need help identifying the model.
We're pretty sure it's a Wells Gardner, but not which model.
It appears to have a VGA input, if that helps.  The pictures are at the end of this thread...
http://forum.arcadecontrols.com/index.php/topic,154877.0.html
« Last Edit: August 01, 2017, 03:45:53 pm by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Ken Layton
  • Guru
  • Technician
Re: Monitor Identification Help - Wells Gardner ?
« Reply #1 on: August 01, 2017, 10:49:05 am »
Probably a D9200 or D9400.
krick
« Reply #2 on: August 01, 2017, 11:30:29 am »
That's what I thought, but the VGA connector doesn't appear to be in the correct spot.
Did later revisions of the D9200 or D9400 come with the VGA port mounted directly on the main board?
Hantarex Polo 15KHz
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #3 on: August 01, 2017, 11:34:46 am »
This is the elusive D9810 series that was the last of the digital CRT 27's because the VGA is mounted on the deflection board. I actually have a dead 9810 board on my shelf. the model number can be confirmed as a sticker on the edge of the board to the right of the VGA connector in between the transformer and the capacitor
the video inputs on a separate input/sync board mounted to the frame on the D9200/9400 series so it's def not one of those.
There is literally ZERO documentation on this board. the closest it comes to is the D9500. If you need repair documentation or specs, you might have to contact WG directly.
krick
« Reply #4 on: August 01, 2017, 11:35:35 am »
Yep.  I just found some pics of a D9800 online and it looks like a match...
https://www.worthpoint.com/worthopedia/wells-gardner-27-wg-d9800-vga-video-470021902
Hantarex Polo 15KHz
« Reply #5 on: August 01, 2017, 11:36:11 am »
jboisvert18
  • Last login:August 17, 2017, 07:29:45 pm
Re: Monitor Identification Help - Wells Gardner D9800 [IDENTIFIED]
« Reply #6 on: August 11, 2017, 06:22:48 pm »
LilShawn, I have been trying to fix this monitor for a while. Can you tell me what is the flyback part # on that D9810 or are you willing to sell your chassis that you said was on the shelf ?
« Reply #7 on: August 11, 2017, 07:05:22 pm »
I can let you know on monday. give me a poke If I don't post a replay here with the info.
The chassis I have here is dead if I recall correctly i think this chassis had a fried I2c rom. been so long and I fixed so many it's hard to remember... I may have a thread here asking about it if you do a search.
also...
http://forum.arcadecontrols.com/index.php/topic,117794.msg1248459.html#msg1248459
jboisvert18
« Reply #8 on: August 14, 2017, 03:05:57 pm »
I have sent you a PM but I am not sure if it works. Cant find it in my outbox
« Reply #9 on: August 14, 2017, 04:57:11 pm »
shady_andy
  • Last login:January 30, 2025, 08:38:55 am
« Reply #10 on: January 28, 2025, 02:15:10 pm »
I just dumped the EEPROM from a D9810 Rev4 monitor while I was recapping a chassis. The chip was labeled as 9810v7. Attached is a ZIP with the bin file, a link to the software I read it with, and a screenshot of the settings and output. Hopefully it helps.
« Last Edit: January 28, 2025, 03:09:36 pm by shady_andy »
