Author Topic: groovymame running at 51% speed when HLSL is turned on  (Read 3185 times)
s8n187
  • Last login:October 10, 2025, 12:50:25 pm
« on: July 27, 2017, 09:55:12 pm »
hi members ,  i just got a AMD 6450 to replace my ArcadeVGA2.  I am now able to run newer groovymame's ,  i have run into a snag which i can't figure out.  If i use HLSL with scanlines Ketsui runs at 51% speed Metal Slug runs at about 34% ,  if i turn HLSL off it runs at full speed.
I will leave my .ini below...........btw crt_emudriver_&_tools_2.0_beta_10_16.2.1_W.7.8.10-64_nieg has been installed as my GFX driver
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   "e:\MAME 0.187 ROMs (merged);roms"
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini;ini/presets
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
swpath                    software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
language                  English
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   lcd
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
waitvsync                 1
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_avi_name             auto
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECT3D POST-PROCESSING OPTIONS
hlslpath                  hlsl
hlsl_enable               1
hlsl_oversampling         1
hlsl_write
hlsl_snap_width           1440
hlsl_snap_height          1080
shadow_mask_tile_mode     0
shadow_mask_alpha         0.1
shadow_mask_x_count       12
shadow_mask_y_count       12
shadow_mask_usize         0.5
shadow_mask_vsize         0.5
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
distortion                0.0
cubic_distortion          0.10
distort_corner            0.10
round_corner              0.05
smooth_border             0.03
reflection                0.0
vignetting                0.0
scanline_alpha            0.5
scanline_size             1.0
scanline_height           1.0
scanline_variation        1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.2
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   0.7,0.7
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                0.95
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,0.95
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_beam_smooth        0.0
vector_length_scale       0.5
vector_length_ratio       0.5
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.2
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.06
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.01
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
« Last Edit: July 27, 2017, 10:10:01 pm by s8n187 »
s8n187
Re: groovymame running at 51% speed when HLSL is turned on
« Reply #1 on: July 29, 2017, 03:29:55 am »
hi again ,  i've been wrestling with this issue since my last post and i have managed to spit out a log.  I can't see anything wrong but maybe you guys can ,  i would also like to say i am running this on a LCD TV pic below ( both my Astros are out of action atm they need a chassis repair ).  When pressing F11 Ketsui is locked to 51% and doesn't move from there and Metal Slug at 34% ,  like i mentioned before if i turn HLSL off both games run at full speed.
strange when HLSL is enabled i get 51% in Ketsui ,  maybe there's an issue with my HLSL settings.......
Code: [Select]
SwitchRes: [ 512]x[ 288]_(52=52.443367Hz) - locked
SwitchRes: [ 512]x[ 448]_(60=60.007648Hz) - locked
SwitchRes: [ 512]x[ 478]_(60=60.007648Hz) - locked
SwitchRes: [ 512]x[ 480]_(60=60.007648Hz) - locked
SwitchRes: [ 512]x[ 512]_(58=58.504505Hz) - locked
SwitchRes: [ 544]x[ 240]_(60=59.973179Hz) - locked
SwitchRes: [ 544]x[ 242]_(60=59.984734Hz) - locked
SwitchRes: [ 544]x[ 448]_(60=60.022945Hz) - locked
SwitchRes: [ 544]x[ 480]_(60=60.022945Hz) - locked
SwitchRes: [ 544]x[ 576]_(52=52.413570Hz) - locked
SwitchRes: [ 560]x[ 240]_(60=59.996170Hz) - locked
SwitchRes: [ 576]x[ 240]_(60=60.015327Hz) - locked
SwitchRes: [ 600]x[ 240]_(60=59.988506Hz) - locked
SwitchRes: [ 600]x[ 288]_(52=52.420712Hz) - locked
SwitchRes: [ 640]x[ 200]_(60=60.003830Hz) - locked
SwitchRes: [ 640]x[ 240]_(60=60.003830Hz) - locked
SwitchRes: [ 640]x[ 256]_(58=58.490974Hz) - locked
SwitchRes: [ 640]x[ 288]_(52=52.433659Hz) - locked
SwitchRes: [ 640]x[ 480]_(75=75.000000Hz) - locked
SwitchRes: [ 640]x[ 480]_(72=72.807693Hz) - locked
SwitchRes: [ 640]x[ 480]_(67=66.995995Hz) - locked
SwitchRes: [ 640]x[ 480]_(60=59.927620Hz) - locked
SwitchRes: [ 664]x[ 496]_(60=59.996288Hz) - locked
SwitchRes: [ 672]x[ 240]_(60=59.996170Hz) - locked
SwitchRes: [ 688]x[ 496]_(60=60.011131Hz) - locked
SwitchRes: [ 688]x[ 512]_(58=58.479279Hz) - locked
SwitchRes: [ 704]x[ 240]_(60=59.988506Hz) - locked
SwitchRes: [ 704]x[ 480]_(60=60.000000Hz) - locked
SwitchRes: [ 720]x[ 464]_(60=59.992352Hz) - locked
SwitchRes: [ 720]x[ 480]_[75=75.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_[72=72.000000Hz] - locked
SwitchRes: [ 720]x[ 480]_(60=59.939049Hz) - locked
SwitchRes: [ 720]x[ 480]_[56=56.000000Hz] - locked
SwitchRes: [ 720]x[ 496]_(60=59.981445Hz) - locked
SwitchRes: [ 720]x[ 576]_[75=75.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[72=72.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[60=60.000000Hz] - locked
SwitchRes: [ 720]x[ 576]_[56=56.000000Hz] - locked
SwitchRes: [ 728]x[ 496]_(60=59.981445Hz) - locked
SwitchRes: [ 728]x[ 576]_(52=52.432957Hz) - locked
SwitchRes: [ 736]x[ 256]_(58=58.476536Hz) - locked
SwitchRes: [ 736]x[ 272]_(55=55.283276Hz) - locked
SwitchRes: [ 736]x[ 496]_(60=59.988869Hz) - locked
SwitchRes: [ 768]x[ 240]_(60=60.000000Hz) - locked
SwitchRes: [ 768]x[ 496]_(60=60.000000Hz) - locked
SwitchRes: [ 768]x[ 512]_(58=58.486488Hz) - locked
SwitchRes: [ 768]x[ 576]_(52=52.439419Hz) - locked
SwitchRes: [ 800]x[ 256]_(58=58.490974Hz) - locked
SwitchRes: [ 800]x[ 288]_(52=52.433659Hz) - locked
SwitchRes: [ 800]x[ 496]_(60=60.011131Hz) - locked
SwitchRes: [ 800]x[ 600]_(75=75.000000Hz) - locked
SwitchRes: [ 800]x[ 600]_(72=72.186188Hz) - locked
SwitchRes: [ 800]x[ 600]_(60=60.315285Hz) - locked
SwitchRes: [ 800]x[ 600]_(56=56.249599Hz) - locked
SwitchRes: [ 840]x[ 544]_(55=55.304939Hz) - locked
SwitchRes: [ 856]x[ 480]_(60=59.992352Hz) - locked
SwitchRes: [ 856]x[ 512]_(58=58.493694Hz) - locked
SwitchRes: [ 864]x[ 496]_(60=60.000000Hz) - locked
SwitchRes: [ 864]x[ 528]_(57=56.854641Hz) - locked
SwitchRes: [ 904]x[ 256]_(58=58.480145Hz) - locked
SwitchRes: [1024]x[ 496]_(60=59.992580Hz) - locked
SwitchRes: [1024]x[ 768]_(75=75.027496Hz) - locked
SwitchRes: [1024]x[ 768]_(70=70.068237Hz) - locked
SwitchRes: [1024]x[ 768]_(60=60.003723Hz) - locked
SwitchRes: [1088]x[ 256]_(58=58.487366Hz) - locked
SwitchRes: [1120]x[ 496]_(60=59.992580Hz) - locked
SwitchRes: [1152]x[ 496]_(60=60.000000Hz) - locked
SwitchRes: [1152]x[ 864]_(75=75.000000Hz) - locked
SwitchRes: [1280]x[ 240]_(60=59.992336Hz) - locked
SwitchRes: [1280]x[ 496]_(60=60.007420Hz) - locked
SwitchRes: [1280]x[ 720]_(60=59.934666Hz) - locked
SwitchRes: [1280]x[ 720]_[59=59.000000Hz] - locked
SwitchRes: [1280]x[ 720]_(50=50.000000Hz) - locked
SwitchRes: [1280]x[ 768]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 800]_[60=60.000000Hz] - locked
SwitchRes: [1280]x[ 960]_(60=60.000000Hz) - locked
SwitchRes: [1280]x[1024]_(75=75.024391Hz) - locked
SwitchRes: [1280]x[1024]_[60=60.019699Hz]
   rng(0): 1280 x1024_60.019699p 63.981000 [fract] scale(3, 2, 1) diff(6.67, 13.
70, 0.8497) ratio(5.714, 2.286)
SwitchRes: [1904]x[ 496]_(60=59.996288Hz) - locked
SwitchRes: [1920]x[ 496]_(60=60.000000Hz) - locked
SwitchRes: [ket] (1) vertical (224x448@59.169998)->(1280x1024@60.019699)
SwitchRes: Modeline "1280x1024_60 63.981000KHz 60.019699Hz" 108.000000 1280 1328
 1440 1688 1024 1025 1028 1066   +hsync +vsync
Switchres: saving    ATI ADL timing "1280x1024_60 63.981000KHz 60.019699Hz" 108.
000000 1280 1328 1440 1688 1024 1025 1028 1066   +hsync +vsync
Switchres: updating  ATI ADL timing "1280x1024_60 63.981000KHz 60.019699Hz" 108.
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -noautoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -unevenstretch
SwitchRes: Setting option -nounevenstretchx
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -filter
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9
Physical width 1280, height 1024
Direct3D: Initialize
Direct3D: Configuring adapter #0 = AMD Radeon HD 7000 series
Direct3D: Adapter has Vendor ID: 1002 and Device ID: 6778
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 1280x1024
Direct3D: First scanline: 41, Last scanline: 1065, Break scanline: 1065, Delay s
canline: -65
Direct3D: Initialize HLSL
Direct3D: First store options
Direct3D: HLSL initialized
Direct3D: Restore options
RawInput: APIs detected
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding keyboard #0: HID Keyboard Device (device id: \\?\HID#VID_045E&PID_
0752#6&10e6313a&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #0: HID-compliant mouse (device id: \\?\HID#VID_045E&PID_008
4#6&2822265d&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #0: HID-compliant mouse (device id: \\?\HID#VID_045E&PID_
0084#6&2822265d&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Region ':maincpu' created
unzip: opened archive file e:\MAME 0.187 ROMs (merged)\ket.zip
unzip: found e:\MAME 0.187 ROMs (merged)\ket.zip ECD
unzip: e:\MAME 0.187 ROMs (merged)\ket.zip has no ZIP64 ECD locator
unzip: read e:\MAME 0.187 ROMs (merged)\ket.zip central directory
unzip: closing archive file e:\MAME 0.187 ROMs (merged)\ket.zip and sending to c
ache
Region ':prot' created
unzip: found e:\MAME 0.187 ROMs (merged)\ket.zip in cache
ache
ache
Region ':tiles' created
ache
ache
Region ':sprcol' created
ache
ache
Region ':sprmask' created
ache
Region ':ics' created
ache
Region ':sram' created
ache
ket_igs027a.bin NOT FOUND (NO GOOD DUMP KNOWN) (tried in ket ket)
WARNING: the machine might not run correctly.
Starting Ketsui: Kizuna Jigoku Tachi (2003/01/01. Master Ver.) ':'
Optional device ':prot' not found
Optional shared pointer ':arm7_shareram' not found
  (missing dependencies; rescheduling)
Starting M68000 ':maincpu'
Starting Timer ':scantimer'
Starting Z80 ':soundcpu'
Starting NVRAM ':sram'
Starting V3021 RTC ':rtc'
Starting Video Screen ':screen'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Optional memory region ':palette:finder_dummy_tag' not found
Starting Speaker ':mono'
Starting Generic 8-bit latch ':soundlatch'
Starting Generic 8-bit latch ':soundlatch2'
Starting Generic 8-bit latch ':soundlatch3'
Starting ICS2115 ':ics'
Direct3D: Get texture target - not found - 448x224:0
Direct3D: Create texture target - 2048x1536
Average speed: 50.72% (6 seconds)
Switchres: restoring ATI ADL timing "1280x1024_60 63.981000KHz 60.019699Hz" 108.
ATI/AMD ADL close
Sound: buffer overflows=2 underflows=0
Direct3D: Store options
E:\0.186>
s8n187
« Reply #2 on: July 29, 2017, 04:04:44 am »
just made a breakthrough ,  it is the mame HLSL settings.  I just used some old ones from another groovymame i have ,  Ketsui and Metal Slug both run at full speed.  So now i have to work on some good looking scanlines.
