Author Topic: Power to Coin Door Light  (Read 1424 times)
SpyhunterUK
  • Last login:December 22, 2017, 05:20:51 pm
« on: July 23, 2017, 05:07:39 am »
I have never done this before but how do I get power to the Coin Door light (see below)?
Thanks.
  • Online Online
  • Last login:Today at 02:10:54 pm
Re: Power to Coin Door Light
« Reply #1 on: July 23, 2017, 06:28:55 am »
Consider swapping the coin door incandescent bulb for a high-intensity wedge-base LED -- longer life, lower current draw.
If you use the SATA to Molex splitter I mentioned in your other post, cut off the last Molex (upper right) and splice extensions to either the 12v/Gnd (yellow/black) or 5v (red/black) wires and run them to the tabs on the coin door lamp socket.
Euro-style terminals are a great choice for splicing the extension wires.
Your choice of soldering or 0.110"(?) Quick Disconnects for the socket connections.
