Author Topic: Exiting a Rom to get back to emulator  (Read 5341 times)
Tom89
  • Last login:July 19, 2017, 10:17:38 am
« on: July 19, 2017, 10:17:38 am »
I FINALLY (YEAH!!!) got it somewhat working... and LOVE IT!!! Needs some control tweaking and few other things, but I am stuck on exiting apps... most all apps (ROMS and BINS); for instance on exiting dig-dug, I cannot get out of it without power cycling the pi-3.  Is there a control/ hotkey sequence I can assign to the X-Arcade for exiting a Rom to get back to the emulator???  Thanks for any help, this is my first post ever after 30 years in the IT field.... damn stroke really killed my memory  :( .
Tom
floyd68
  • Last login:August 19, 2021, 02:06:00 pm
Re: Exiting a Rom to get back to emulator
« Reply #1 on: October 09, 2017, 11:10:53 am »
I am having the same problems.
Have you figured out the fix?
Titchgamer
« Reply #2 on: October 09, 2017, 02:49:01 pm »
Bit confused are you using MA or a Pi3?
If Pi3 the default to exit is Start & Select.
In MA its whatever you set it at, default is esc key I think?
