Author Topic: Questions about Orange PI and Retrorange.  (Read 4757 times)
victor861
  • Last login:July 22, 2017, 01:54:07 pm
« on: July 13, 2017, 03:46:16 pm »
Hi. I want to build an arcade machine with two players.
Its possible use these usb joysticks in Orange Pi?
https://m.es.aliexpress.com/s/item/32640789746.html?spm=a2g0n.search-cache.0.0.2e3cd2c0HqmUWM
Another question about retrorange, i use these shaders on retroarch in pc, can i used it in retrorange?
https://forums.libretro.com/t/analog-shader-pack-version-3-is-here/5493
A lot of thanks.
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
Re: Questions about Orange PI and Retrorange.
« Reply #1 on: July 14, 2017, 07:34:36 am »
Yup!
A lot of thanks.
I doubt it, but you can use certain shaders and overlays for sure.
But if you bought an Orange Pi, try it yourself. If you didn't buy one: consider the RPi3 instead. You would probably don't notice the few extra bucks the RPi costs, but it will save you from a lot of possible frustrations.  The Orange Pi's just don't have that community you would want for a fully out-of-the-box functional retro gaming system.
« Last Edit: July 14, 2017, 07:39:12 am by barrymossel »
victor861
« Reply #2 on: July 14, 2017, 10:00:20 am »
Thanks for you answer. Yes, im considering buy the Raspberry,  but the Orange is cheaper (15€ and Raspberry 45€ in spain).
I need to think what machine buy.
A lot of thanks.  (Sorry for my english)
barrymossel
  • Spectrum
« Reply #3 on: July 15, 2017, 02:32:02 am »
I bought an Orange Pi because it seemed a bit faster than the RPi3. Eventually I ended up buying a RPi3 as the Orange Pi didn't play well with a normal HDMI to VGA adapter (RetrOrangePi dev told me YMMV). Besides that issue, working with such a "clone" is just not the real experience. Shaders not working, certain wifi adapters not working, etc. You can try, but don't expect "support" when it doesn't work.
Titchgamer
« Reply #4 on: July 15, 2017, 06:48:56 am »
Putting aside the above dont cheap out on your hardware (any of it) because 1) it will frustrate you and 2) cost you more because you end up upgrading anyway!
ark_ader
  • I glow in the dark.
« Reply #5 on: July 19, 2017, 12:55:05 pm »
Buy what you can afford.  Learn how to use it in your application and document.  Without people like you taking the plunge for an alternative, it is hard to form a consensus of opinion.
In this day of age, saving a few euros is worth the effort.  I applaud you.  :applaud:
SNAAKE
  • Trade Count: (+29)
  • Last login:November 16, 2025, 04:44:38 pm
« Reply #6 on: August 15, 2017, 01:16:12 pm »
shader dont work with orange pi...
otherwise great cheap cheap board. I set some of these up recently. orangepi one isnt that good it locks up whenever. Id rather pay $5 more for the pi pc instead..and you get the faster cpu..
