Author Topic: motherboard mouting hardware, what to use?  (Read 2599 times)
imJGott
  • Last login:September 15, 2017, 09:10:01 pm
« on: July 12, 2017, 11:33:40 pm »
hello,
what are people using to mount a motherboard inside of a bartop arcade style cabinet? im trying to look for nylon mounts but unsure as to what to look for exactly. thanks!
JDFan
Re: motherboard mouting hardware, what to use?
« Reply #1 on: July 13, 2017, 12:02:43 am »
PCB mounting feet - if you need them fairly quick Ebay has them 10 for $4.57 ( http://www.ebay.com/itm/10-PCB-Board-Mount-Leg-Feet-L-Post-Bracket-Jamma-Pinball-Arcade-Vewlix-CandyCab-/182139243833?epid=1970523391&hash=item2a68584d39:g:nIkAAOSwq5pXPpyi )
or if you can wait 2 or 3 weeks - 10 for $0.99 (without screws) from China/Hong Kong ( http://www.ebay.com/itm/10-20-50pcs-fixed-plastic-PCB-mounting-feet-20mm-L-type-feet-without-Screws-/112462029076?var=&hash=item1a2f426114:m:mpserav_PlVlKwM6GZoCOFw )
OR if you want a cheaper method cutting up an old Bic plastic pen into pieces works also !
« Last Edit: July 13, 2017, 12:05:41 am by JDFan »
imJGott
« Reply #2 on: July 13, 2017, 11:08:27 pm »
Thank You so much!
gedman
  • Last login:November 26, 2021, 01:25:30 pm
  • My first cab is almost done. Loving the challenge.
« Reply #3 on: July 14, 2017, 09:21:00 am »
I used some narrow rubber tubing (airhose line for a fish tank).  Short pieces are rigid enough to do the job.  Screw goes through the hole on the mother board, through the tube piece and then screws into the side of the cab.
« Last Edit: July 14, 2017, 09:34:52 am by gedman »
« Reply #4 on: July 15, 2017, 08:40:10 pm »
I've used bic pens cases. I'd cut them with wire cutters and then pass the screw through the motherboard, through the case and into the wood.
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #5 on: July 20, 2017, 12:16:05 am »
I used these:
https://www.amazon.com/gp/product/B0026GUEN4/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
And used standard computer standoff screws, scavenged from the PC.
jennifer
« Reply #6 on: July 20, 2017, 12:38:33 am »
      Jennifer likes fun colors and longevity.... Anodized aluminum
« Last Edit: July 20, 2017, 12:40:47 am by jennifer »
ark_ader
  • I glow in the dark.
« Reply #7 on: July 20, 2017, 01:57:01 am »
Get some small wood screws and paper washers and drill the board directly to the cab wall.  Or to assist in proper cooling get a cheap PC case.
« Reply #8 on: July 20, 2017, 11:29:14 am »
BYOAC user Severdhed has some great examples of the bic pen mount here:
http://forum.arcadecontrols.com/index.php/topic,95017.msg1017156.html#msg1017156
He also mounts a video card in the same way to make it nice and sturdy.   :applaud:
DeL
jennifer
« Reply #9 on: July 20, 2017, 12:06:11 pm »
   Big fancy board, and mounted on recycled garbage?.... I would feel so cheated to buy/sell that kind of workmanship. :banghead:    https://www.unicorpinc.com/standoffs.htm
« Last Edit: July 20, 2017, 12:25:46 pm by jennifer »
Smoke-Inator
  • Last login:January 24, 2021, 09:45:31 pm
« Reply #10 on: July 21, 2017, 11:36:31 am »
not sure if radio shack still exists but, ive purchased "stand off's" for a few bucks....that are black plastic outside and metal inside threaded for motherboard sized screws
