Author Topic: Howler PCB - Troubleshooting JOY1  (Read 3973 times)
lobeline
  • Last login:July 12, 2017, 12:58:44 pm
« on: July 10, 2017, 10:30:34 pm »
Hi everyone,
I'm new to this realm, and tried to tackle a MAME project. I had a Howler 4P PCB I wanted to use and tried that. I have a 2P config, and I wired everything up. For some reason though I cannot get JOY UP nor DOWN to work. I've tried swapping out the cables, daisychain, and even used a different joystick. Nothing seems to be helping. I have nothing plugged into either 3V3 ports. And I did unscrew and tighten to each wire coming in.
Any advice? Thank you!
Re: Howler PCB - Troubleshooting JOY1
« Reply #1 on: July 11, 2017, 11:11:02 am »
Set it on fire & get an iPac?   :badmood:
lilshawn
  • Last login:Yesterday at 11:14:57 am
« Reply #2 on: July 11, 2017, 11:32:23 am »
if the wiring is good, it's probably dead inputs.  not much you can do. contact whomever you got it from and see if you can't exchange or return it as defective.
  • Last login:Yesterday at 08:28:20 am
« Reply #3 on: July 11, 2017, 11:34:16 am »
Move the wires to unused inputs and remap your controls in MAME.
