Author Topic: Frame Delay setup tool  (Read 3221 times)
jimmer
« on: June 29, 2017, 05:03:10 am »
Has anyone written a (windows) tool to test run each ROM and then write for each a ini file with appropriate frame_delay ?
Is there anything wrong with this idea (in case I try to do it myself) ?
big10p
  • Mmmm, arcade classics!
Re: Frame Delay setup tool
« Reply #1 on: June 29, 2017, 05:57:52 am »
I just use the D3D9EX build which sets the optimal frame delay automatically. Well, that's what I was told, and it seems to work well, but someone correct me if I'm wrong.
jimmer
« Reply #2 on: June 29, 2017, 07:56:31 am »
Thanks for the reply.
Unfortunately I'm not ready to upgrade from XP yet, so it looks like I might have to do something for myself.
inv
  • Last login:August 10, 2020, 10:35:44 pm
« Reply #3 on: June 29, 2017, 02:35:59 pm »
You need a frontend, maybe mamepgui.exe.
makya
  • Last login:December 16, 2025, 10:25:53 am
« Reply #4 on: June 29, 2017, 05:57:51 pm »
Iirc d3d9x removes the 3 frame buffer even at frame delay 0. With d3d in winxp you can safely achieve the same with frame delay 1.
donluca
  • Last login:December 31, 2025, 12:32:56 pm
« Reply #5 on: June 30, 2017, 06:35:12 am »
That's not true.
All that D3D9ex does is skipping the frame queue, so that instead of having 3 frames of delay in D3D9, you only have 1.
*then* you have to play around with frame_delay to remove that last frame of lag.
A software which runs some game in benchmark mode with various frame delay value and set them accordingly would be a god send.
I'd know how to do this in Linux/Unix/Mac OS, but absolutely clueless if batch scripting allows for what I'd like to do in Windows.
2.- Inflatable dolls
big10p
« Reply #6 on: June 30, 2017, 06:56:35 am »
That's not true.
Ah well, if that's the case, I think that's good enough for me. 1 frame of lag I can live with.
