Author Topic: Please Help! Jvspac to Xbobx360 problem  (Read 1935 times)
chowmarcus
  • Last login:August 16, 2019, 01:19:02 am
« on: June 22, 2017, 06:19:21 pm »
Hi all,
Hope someone can help me. I'm trying to connect my Xbox360 to my Sega Lindbergh JVS cab with a Jvspac and Cronusmax Plus. I have read some others have successfully done that with ease.
I have updated my Jvspac to the latest firmware for PS3 and updated my Cronusmax Plus as well. However the Xbox360 just won't detect the controls. I have tried messing around the plugins for Cronusmax Plus but I'm not sure what to do... Anyone has tried this before? Or anyone can suggest another easy way to connect a Xbox360 to a JVS cab? thanks alot!
Marcus
ark_ader
  • I glow in the dark.
Re: Please Help! Jvspac to Xbobx360 problem
« Reply #1 on: June 22, 2017, 08:00:53 pm »
As I posted elsewhere on here I got my Xarcade working with the Cronus on the Xbox One.  So with everything being equal, if the JVSPAC is HID compliant then it should work.  Did you upgrade the firmware on the Cronus?  If you have the old Cronus you can upgrade to the latest firmware for $29.00 as the old deal for free is now over.
http://cronusmax.com/tag/free-upgrade/
chowmarcus
« Reply #2 on: June 23, 2017, 06:34:56 pm »
Thanks for the reply! Yes I'm using the new Cronusmax Plus and I have updated to the latest firmware. I have also updated my JVSPAC to the PS3 firmware as well instead of the original MAME version. Would that make a difference? and do I need to use enable direct input in Cronusmax or using plugins like XAIM? Thanks!
