Author Topic: Can I display 60hz on my 50hz TV using GM  (Read 10761 times)
ArcadeSpirit
  • Last login:July 01, 2017, 09:18:27 pm
« on: June 15, 2017, 07:28:58 am »
Hi everyone and thanks for taking your time to look at this post.
I have been trying for a whole 3 days to get Groovymame working on my 50hz PAL TV with the help of CRT Emu_Drivers.
I am using the UMSA adapter along with a standard scart cable.
I have followed many instructions on how to set up groovy and how crt emu drivers work but I stil get no clear picture.
After everything is installed I turn off my PC plug my VGA into my UMSA adapter and then turn on my PC. Wait a minute and then my TV.
I do get a picture but it looks to be out of synch, basically it looks like I would need to tune it in if I was using it as a normal TV with ariel.
Please can anyone help?
makya
  • Last login:December 16, 2025, 10:25:53 am
Re: Can I display 60hz on my 50hz TV using GM
« Reply #1 on: June 15, 2017, 06:33:01 pm »
hello, is the UMSA powered?
(user machyavel here, lost my pwd / email accnt...)
haynor666
  • Last login:Yesterday at 01:58:04 pm
  • retro maniac
« Reply #2 on: June 16, 2017, 03:19:45 am »
Judging from photo is powered from external PSU.
  • Last login:Today at 06:18:40 pm
« Reply #3 on: June 16, 2017, 05:42:27 am »
You don't provide enough information. There are two different versions of CRT Emudriver: 1.x and 2.0, both are installed in completely different ways. Then there is Windows XP or on the other hand you have Windows 7/8/10, which again are configured in different ways. Then you have legacy cards (pre-HD 5000) and HD 5000+ cards, which are also configured differently.
etc.
« Last Edit: June 16, 2017, 05:43:58 am by Calamity »
haynor666
  • retro maniac
« Reply #4 on: June 16, 2017, 07:27:34 am »
You can try switch polarity on UMSA. MAybe that's problem.
ArcadeSpirit
Are these settings correct for GroovyMAME
« Reply #5 on: June 19, 2017, 07:49:26 am »
Hi everyone,
I have set up GroovyMAME and VMM and I just wanted to check if this was correct.
I am using a standard PC CRT Monitor, the brand of monitor is TINY.
I also have a Radeon 9200 PRO
I am using Win XP 32bit
VMMaker
MonitorType = "CUSTOM"
monitor_specs0    15625.00-15625.00, 50.00-50.00, 1.500, 4.700, 5.800, 0.064, 0.160, 1.056, 0, 0, 192, 288, 448, 576
   XresMin_XML = 240
   YresMin_XML = 160
   YresRound_XML = 4
   XresMin_Custom = 240
   YresMin_Custom = 160
   YresRound_Custom = 0
ARcade OSD
640*40 60p 60.00 native
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
console                   0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   arcade_31
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
multithreading            0
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             0
waitvsync                 0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  0
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       6
shadow_mask_usize         0.1875
shadow_mask_vsize         0.1875
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
curvature                 0.03
round_corner              0.03
reflection                0.03
vignetting                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
I have also noticed when I start up groovyMAME all my games run at 640x480p 60.00hz but no Khz is displayed
haynor666
  • retro maniac
Re: Are these settings correct for GroovyMAME
« Reply #6 on: June 19, 2017, 09:17:25 am »
No, In VMMaker You are setting PAL TV but in mame.ini arcade_31 mode not too mention that ini seems to be a bit outdated (multithreating was removed from mame).
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« Reply #7 on: June 19, 2017, 10:56:30 am »
Agreed, which version of GM are you using? Use "mame -cc" at command line to generate a new ini and make edits to that.
ArcadeSpirit
« Reply #8 on: June 19, 2017, 11:06:13 am »
Thanks for the reply Haynor.
I have moved on from that problem and created another one for myself.
Here is my setup
Win XP 32
Radeon 9200 PRO
VMM ver1.4b
CRT_emu 1.2b
Arcade OSD
Groovymame 0.161
PAL TV x1 SCART input
Is this setup ok to produce an image on my TV.
I have tried with these settings and I only get this..
I set VMM maker to produce lines, change mame.ini I then run VMM.
Turn off PC then attach TV through UMSA...
This is what I get.
ArcadeSpirit
« Reply #9 on: June 19, 2017, 11:38:43 am »
Here is another picture I have of the TV. I can see the Arcade OSD in the background but is this out of sync and if so how can I correct this. Its taken me three weeks to get to this point...please help...I have read and watched many video and information...Im getting to my wits end...I can feel it getting closer but this last hurdle...arrrgghhh
haynor666
  • retro maniac
« Reply #10 on: June 19, 2017, 12:08:11 pm »
ArcadeSpirit, this is what You need:
Groovymame x32 186 - https://mega.nz/#!xgd1QAhC!R5VSwQSr6nIiNMWEF0_jAK9gyprY1wrcq6p6Nb9DxnM (it's my own build, tested)
ArcadeOSD - https://drive.google.com/open?id=0B5iMjDor3P__RmU0dk1ieE9IazA
Driver - http://mame.3feetunder.com/windows-ati-crt-emudriver/crt_emudriver_6.5_1.2b_xp_32.exe (use only driver, DO NOT use ArcadeOSD from this package)
Instruction (partially suitable for XP x32) - http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=1016#p1016
Post Your exact TV model, please. Your UMSA is powered from external PSU or from PC internal PSU? Polarity on UMSA should be set to postive.
« Last Edit: June 19, 2017, 12:19:38 pm by haynor666 »
ArcadeSpirit
« Reply #11 on: June 19, 2017, 12:24:22 pm »
Thanks Haynor I am just in the process of formatiing my HDD and re-installing XP just so I know I am in a fresh place.
I will follow your instructions accordingly and post from there.
The model of my TV is:
Mitsubishi CT1535TX 50Hz PAL TV made in UK (Colour TV Receiver)
I have looked online but can not find anything on it.
My USMA is powered through mains supply not from PC.
ArcadeSpirit
« Reply #12 on: June 19, 2017, 12:28:20 pm »
And my USMA set to Positive. Thank you for your help I will post in due course.
Just to clear my head, once I have completed the set=up is my TV capable of doing this or do I have to have a specific TV?
haynor666
  • retro maniac
« Reply #13 on: June 19, 2017, 12:33:32 pm »
Sony Trinitrons (silver ones) are 100% tested (except 100 Hz models) many Philips, Samsung (with problems from my experience) and Grundig will work. Basically any TV with PAL and NTSC support will work.
I cannot find any information about this TV either. In what year was produced ? TV from around 2000 and newer should work also with NTSC signal (plenty from even 1990 will work also).
Recapnation
    • Eiusdemmodi
« Reply #14 on: June 19, 2017, 12:38:39 pm »
You need a 60-Hz TV set/monitor for GM usage. How in the world are you going to properly emulate 60-Hz games with 50-Hz-only hardware.
Said that, I hardly believe that TV set is 50 Hz-only, especially if it supports RGB. Anyway, you should get yourself something better (bigger) no matter what beforehand. And also think why are you using old versions of ---smurfing--- everything.
ArcadeSpirit
« Reply #15 on: June 19, 2017, 12:42:30 pm »
I can not find a year of manufacture on the TV set... I think it is before 2000 looking at it from that point of view.
I will try out the method as posted above and keep you updated as I go.
Also I forgot to ask what version of MAME should I be using
ArcadeSpirit
« Reply #16 on: June 19, 2017, 12:59:20 pm »
Hi Haynor I have just started to install CRT-Emu drivers on Win XP with the files you gave me but having followed your instructions I do not get the same set-up screen and a message saying Radeon 9250 - Secondary has not been passed...anyway I clicked continue twice and then all I have is a screen asking me to re-start... Have I got the right file here?
haynor666
  • retro maniac
« Reply #17 on: June 19, 2017, 01:03:11 pm »
Recapnation, You are right but I think his hardware is too old for windows 7 (lack of drivers for windows 7) so he is forced to use old drivers, XP but he should use new tools. Otherwise new groovymame might now work correctly.
ArcadeSpirit, post photos. I'm using HD4350 and never had problems but I use newer driver 9.3.
« Last Edit: June 19, 2017, 01:12:27 pm by haynor666 »
ArcadeSpirit
« Reply #18 on: June 19, 2017, 02:08:18 pm »
I only have Windows XP 32 bit version... I am going to do another fresh install because I have once again messed this up...
I did notice that on the install through crt-emu drivers I did get an error message...would this be normal? I also do not have the same options are per instrucrions posted by Haynor....
I do not get the option to install drivers or go to TESTSIGNING...
haynor666
  • retro maniac
« Reply #19 on: June 19, 2017, 03:04:21 pm »
TESTSIGNING is only for windows 7. I think It's better to do not follow this instruction for now. After all it's for windows 7.
Use only PC monitor for setting. Just disconnect everything from second output and then install XP.
After You end with XP just install driver using setup inside driver folder and restart PC. Do You have picture on PC CRT monitor?
If yes, then run ArcadeOSD 2.0 beta 10 (EDIT. Does not work for me, dummo why). How many modes do You have ? 5, 10 or about 60 ? Do you have modes with 50 Hz ? If no, then we need ArcadeOSD with custom resolutions.
Ups, no 50 Hz modes by default so we need ArcadeOSD (old one for now from beta 8 archive, for unknown reason ArcadeOSD from beta 10 does not recognize old 9.3 driver). Set options:
Press ok, then Generate modes. All modes should be as 50 Hz.
Now set any 50 Hz mode (better big one, interlaced like 640x512, no more than 800x600). You will probably loose picture on CRT PC. If yes, switch VGA cable to TV. Do You have picture ?
« Last Edit: June 19, 2017, 03:56:20 pm by haynor666 »
ArcadeSpirit
« Reply #20 on: June 19, 2017, 03:59:26 pm »
Hi Haynor here is my process from start to finish and all I ended up with was a blank screen on my PC CRT anda fuzzy picture on my TV
The photos show u my process
ArcadeSpirit
« Reply #21 on: June 19, 2017, 04:01:17 pm »
following on...
ArcadeSpirit
« Reply #22 on: June 19, 2017, 04:03:41 pm »
I did not turn off my PC again to get the picture on my TV I just swapped plugged in my TV to VGA see last picture
haynor666
  • retro maniac
« Reply #23 on: June 19, 2017, 04:19:15 pm »
Your PC was probably switched to 640x480@60Hz. That's why You don't have any picture on CRT PC but distorted picture on TV. Something tells me that Your TV might be really 50 Hz only. Years ago I had however polish TV Elemis 50 Hz in theory but somehow I get stable picture even with 60 Hz mode.
Possible solution - before You install CRT emudriver set resolution to 1024x768 on PC monitor. Then install driver and restart PC. If You see picture after reset run ArcadeOSD beta 8 and set LOCK UNSUPOORTED MODES to NO. Now browse video modes and try set any. Then switch cable to UMSA.
BTW. I try to simulate 50 Hz only TV but I installed 50 Hz only modes after restart I didn't see any 50 Hz. I think my system detects 50 Hz modes as unsuitable. I switched Lock unsupported modes to NO and then I was able to set (but not always).
I wrote message to Calamity. Maybe he can help and look at beta10 issue.
« Last Edit: June 19, 2017, 04:34:23 pm by haynor666 »
« Reply #24 on: June 19, 2017, 04:51:26 pm »
Why positive sync?
haynor666
  • retro maniac
« Reply #25 on: June 19, 2017, 04:53:01 pm »
It works like that with UMSA. Maybe creator made a mistake in labels on circuit.
I was able to set 50 Hz modes but after I switch to TV and restart PC so after all it's some kind of detection problem of my LCD.
« Reply #26 on: June 19, 2017, 05:04:16 pm »
I never had to touch the sync polarity switch on my UMSA.
haynor666
  • retro maniac
« Reply #27 on: June 19, 2017, 05:05:34 pm »
Me to. Just of curiosity I switched to negative sync and don't get any picture on TV. Switched back to positive and everything is fine.
ArcadeSpirit
« Reply #28 on: June 19, 2017, 05:22:30 pm »
Wear can I download beta8 version from I have searched but can not find
haynor666
  • retro maniac
« Reply #29 on: June 19, 2017, 05:38:08 pm »
Older version is not available. Try beta 10 and see if this card will compatible with beta 10. Might be my own problem with HD4350.
ArcadeSpirit
« Reply #30 on: June 19, 2017, 05:43:42 pm »
I followed your instructions Haynor and this is what I got on my TV. My PC monitor worked fine in the mode you told me to change it to but on every setting of ArcadeOSD none of the mode lines display on my TV. I can make out the screen behind all the fuzz so I know SwitchRes is outputting 15khz but I guess my TV is not compatible?
ArcadeSpirit
« Reply #31 on: June 19, 2017, 05:44:51 pm »
I can see the geometry screen on my TV but why does it look out of sync?
ArcadeSpirit
« Reply #32 on: June 19, 2017, 06:02:02 pm »
I am curious what Groovymame version and MAME version to use if I am using Win XP 32bit version?
I have been told to use so many different versions I just want to know what I need to use exactly...
Sorry I have used so many different versions with different results I just wanted to know if they was optimal version to use per OS.....
ArcadeSpirit
« Reply #33 on: June 19, 2017, 06:31:23 pm »
When I run CRT Beta 10 I get this...
ArcadeSpirit
« Reply #34 on: June 19, 2017, 06:35:22 pm »
I then create modelines then I get this
ArcadeSpirit
So I started from scratch... GM Win XP32
« Reply #35 on: June 19, 2017, 07:53:29 pm »
So I started from scratch and this is what I got...
Win XP32
Crt_Emu
Radeon 9000 Pro
I create this is VMM
went to Arcade OSD
selected setting as picture...
Swapped CRT Monitor for my 50Hz PAL TV and this is what I got...
How is this possible?
haynor666
  • retro maniac
« Reply #36 on: June 20, 2017, 01:33:36 am »
You have the same problem as me - your card is not detected just like my HD4350.
« Reply #37 on: June 20, 2017, 04:52:57 am »
ArcadeSpirit,
Please stop opening new threads for the same issue, it makes it difficult to follow the issue.
With regards to the "beta 10" detecting issue mentioned by haynor666, it's a different problem that I'll be focusing on soon, but has nothing to do with OP's problem, as long as he sticks with 1.x tools.
Some things I'd try:
- Use a different scart cable. Yes, I know it sounds stupid but it's not the first time I've seen it, promise. Make sure you use a fully wired RGB scart cable. Yes, many scart cables are not fully wired.
- Try both polarity settings in your UMSA.
- In Arcade OSD, instead of trying a low resolution like 320x240 go straight to 640x480@60i (or 50i). This is in order to discard low dotclock issues.
ArcadeSpirit
« Reply #38 on: June 20, 2017, 11:18:14 am »
No problems I will attend to this post for now... sorry for the mistake.
I will try this with a better SCART cable and see what happens.
With regards to just using my PC CRT monitor I have set it up to use a 31.5Khz setting in my monitor specs lines but I have noticed black borders around some games i.e Neo Geo and Wrestle-Mania by Midway and Cotton...
monitor_specs0    31000-31500, 50-65, 0.636, 3.813, 1.906, 0.318, 0.064, 1.048, 0, 1, 576, 768
Here are the rom.txt files.
I did notice by changing my settings (red text) in the crt_range line in GroovyMAME I eliminated the problems on the NEO Geo games and Cotton but not Wrestle-mania.
crt_range0    31130-31500, 49.50-65.00, 0.940, 3.770, 1.890, 0.349, 0.064, 1.017, 0, 0, 400, 512, 0, 0
Here is the example....(see picture)
I would just like to know if I can alter these so all games fit my screen...
I have read about creating mode lines for individual monitors...From what I have read I am going to change the PORCH settings in GroovyMAME to help alleviate the problems...If I am heading in the right direction that's cool but if I need to start somewhere else please let me know.
I like the appearance just using my PC CRT monitor, at 31.5Khz I have noticed scan lines on my games and every game seems to run very smooth and looks great, especiall "In The Hunt" really pops off the screen.. The only problem I am having now is that of black borders around some games...
Should I post this as a new thread or keep it on here...
New to forums so please excuse the fact I don't know what I'm fully doing yet  ;D
