Author Topic: Lockable power button for mame? (Parental control)  (Read 3990 times)
thepro8
  • Last login:May 15, 2023, 07:30:25 pm
« on: June 08, 2017, 11:45:09 am »
Any recommendations on a power button option that need a key or something to turn it on then? My wife wants to make sure kids aren't playing it all the time.
  • Last login:November 10, 2025, 03:44:56 am
Re: Lockable power button for mame? (Parental control)
« Reply #1 on: June 08, 2017, 12:00:53 pm »
 :laugh2:
Just tell her to wait 2 weeks.  They'll lose interest.
JDFan
« Reply #2 on: June 08, 2017, 12:13:31 pm »
Coin door and token allowance (token payment for extra chores done )  :cheers:
  • Last login:Today at 06:30:55 am
« Reply #3 on: June 08, 2017, 12:39:16 pm »
Tell your kids when they can and cannot play. :dunno
  • Last login:Today at 07:16:07 pm
« Reply #4 on: June 08, 2017, 12:39:37 pm »
Search Amazon for "key switch" -- there are lots of options.   ;D
Will you put the switch in series with a power pushbutton (low amperage) or will you put it in series with the power line? (higher amperage)
Make sure that the switch is rated for how you want to wire it.
Titchgamer
« Reply #5 on: June 08, 2017, 02:06:49 pm »
This.
Ronnis key switch is prob the easiest option.
Just remember to shutdown the device before turning off the key switch!
thomas_surles
« Reply #6 on: June 08, 2017, 06:53:53 pm »
You could just keep the power on the inside like behind the coin door or something.
gedman
  • Last login:November 26, 2021, 01:25:30 pm
  • My first cab is almost done. Loving the challenge.
« Reply #7 on: June 08, 2017, 08:22:49 pm »
Here is a potentially crazy idea...
Setup the PC boot into Windows with a password required. Choose a password using only characters that are transmitted to the PC via your joysticks and buttons. Like this: https://www.ultimarc.com/jpac2.html
Even if your kids turned on your game, they would need to know the right "magic combination" of joystick/button movements to be able to login and play.
For example, set the password to 12GDRFA, and then use these control panel actions to enter the password:
Start1 > Start2 > Joystick2Right > Joystick2Left > Joystick2Up > Joystick2Down > Player2Button1, followed by Start1+Joystick1Left (which is the Shift command for the keyboard <Enter> key).
Anyone know if that would work?
paigeoliver
  • Awesome face!
« Reply #8 on: June 08, 2017, 09:42:58 pm »
:laugh2:
That is the correct answer.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #9 on: June 10, 2017, 12:46:16 am »
up up down down left right left right B A select start  :dizzy:
Titchgamer
« Reply #10 on: June 10, 2017, 04:41:14 am »
B, A, Right, A, C, Up, Down, A.
thepro8
« Reply #11 on: June 12, 2017, 12:46:09 pm »
I like this idea.
nugarp
  • Last login:November 09, 2025, 11:22:06 pm
« Reply #12 on: June 21, 2017, 10:16:59 pm »
You could use a switch to power off the monitor instead of the system. I.e. It must be in the in position to turn on. You can do that pretty easily with something like a power tail switch (I think that's what it's called) if you're not comfortable splicing power cables.
Personally, I run a nodejs server running express so I can turn things on and off from my phone over wifi. not a physical switch though.
« Last Edit: June 21, 2017, 10:18:38 pm by nugarp »
Wheel2XInput | HDRecoil | LeaderLamps | NetLauncher | Discord | Youtube
