Author Topic: Panel Mount USB options  (Read 1777 times)
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« on: January 27, 2004, 04:27:13 pm »
I would like to add a couple of USB ports externally on my cab (for players 3/4, dance pads, etc etc)   but haven't found too many nice looking options.
Actually really only one so far at:
http://www.datapro.net/products/1598.html
and they have a mounting plate here:
http://www.datapro.net/products/73202.html
Anyone use the above before or are there any other suggested methods for doing this?
Space Warped by Someone
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re:Panel Mount USB options
« Reply #1 on: January 27, 2004, 04:58:05 pm »
How about finding a small 4 port hub with a flat face that you can mount flush to the CP with only a little creative mounting?
something like this
or this?
Then you'd only have to run one USB cable to the control panel, but could connect several USB gamepads (or whatever).
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: January 27, 2004, 06:08:17 pm »
I have this on the shelf on my cabinet.
Copy and paste the link into a brand new browser.
http://free.hostdepartment.com/S/SirPoonga/images/y_cab_usb.jpg
I took a usb expansion (the find that fits in an expansion slot that hooks to a computers usb header), took off the ports from the sheet metal.  Then I cut holes in my plexi.  Evertually, there will be artwork under the plexi so it will just look like two rectangles in the end.
Witchboard
« Reply #3 on: January 27, 2004, 06:41:19 pm »
I was planning on putting a couple USB ports right above my coin door.  I was just going to use the ones that mound in the back of the computer.  I planned on bend the plate straight and screw them on from the inside with maybe a door covering them on the outside.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #4 on: January 27, 2004, 11:39:19 pm »
I'm going with this one:
http://www.datapro.net/products/70202.html
It's certainly not the cheapest solution, but it's the cleanest looking method that I've found.  I'm mounting it directly underneath the bottom of the CP (face down).
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: January 28, 2004, 07:28:16 am »
something like this
or this?
I agree with MineralAl on this one.  Another option is the type of hub with 2x2 stacked ports, like this one from newegg -
http://www.newegg.com/app/ViewProductDesc.asp?description=17-111-490&depa=1
