Author Topic: Anyone use these before? Top mounted restricter plates from ????  (Read 2339 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
I looked and saw very little info on these and none here that I could find.
I saw this Arcade Joystick switchable Restrictor
 http://www.mameroom.com/webstore.asp?productid=JOYSTICKRESTRICTOR&category=195
 & http://www.hollandcomputers.com/store/pc/Arcade-Joystick-switchable-Restrictor-plate-for-4-or-8-way-play-For-Sanwa-and-Zippy-ball-top-Joysticks-p10851.htm
They sell them on Ebay also so I don't know who makes them, but was wondering if they were any good. I'm looking for a new easy top switchable nonelectrical option for a common joystick.
I hate to drop $40 or 50 on a  gimmicky worthless option.
(edit- yes I know about magstick u360 ... :) )
« Last Edit: May 27, 2017, 12:32:40 pm by tommyinajar »
n3wt0n
Re: Anyone use these before? Top mounted restricter plates from ????
« Reply #1 on: May 27, 2017, 03:17:06 pm »
There is an earlier post about them here. It appears a lot of people bought them but there wasn't a lot of feedback on how they actually worked.
http://forum.arcadecontrols.com/index.php/topic,150563.msg1573631.html#msg1573631
tommyinajar
« Reply #2 on: May 27, 2017, 05:49:42 pm »
Thanks much! I wanted to see what was involved and how rough of movement it was. Seems like a lot of people bought them, but only 1 installed it or at least wrote about it. It was also moved to reviews from the thread.
http://forum.arcadecontrols.com/index.php/topic,150713.0.html
I was also searching for retoarcade.us and Holland computers who sells them so that didn't help.
Looks like they work good. Off to order a couple. Thank you again.
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
« Reply #3 on: May 29, 2017, 01:42:46 am »
I just responded in the other thread, but I'll post it here as well:
I've had mine installed for awhile.  They work as advertised and saved me a heap of trouble/money.  I think it works great and was well worth the investment for what I was looking for.
I can imagine that many here would object to the aesthetics of it.  They're not the prettiest, but not objectionable to me for my setup.
smass
  • Last login:December 05, 2024, 06:12:33 pm
  • Cheapskate Arcade
« Reply #4 on: May 29, 2017, 03:09:47 pm »
I am considering getting one of these for my tankstick, however the buttons are pretty close to the joystick so I am not sure if the plate will fit without relocating the joystick...
Could you do me a favor and measure the diameter of the plate?  I can't find this info anywhere.  Thanks! :)
« Last Edit: May 29, 2017, 03:11:45 pm by smass »
megamoze
« Reply #5 on: May 31, 2017, 08:07:06 pm »
I'll measure it first chance I get.  But my CP is actually based on the tankstick layout, so it SHOULD fit on yours.
