Author Topic: Williams Firepower  (Read 18003 times)
  • Last login:Yesterday at 11:26:54 pm
Williams Firepower
« on: May 22, 2017, 10:35:11 pm »
Symptom - lower left segment missing from players 1 & 2 and ball/credit displays.
So that means the problem isn't display glass, took a look at the board, and we've got a crispy resistor.
Replaced it with a half watt flame proof...
And.... There....we.... Go.
« Last Edit: May 22, 2017, 10:43:01 pm by pbj »
Re: Williams Firepower
« Reply #1 on: October 17, 2020, 07:17:37 pm »
3.5 years later, same segment went dead again and took its friend top segment with it.
Replaced the resistor again and that segment was resolved.
Top segment was a little weird, resistor looked and tested okay.  Reflow of everything did nothing.
I looked at the schematics and saw there are two chips that player 1, 2, and ball/credit have in common.  I looked over a data sheet and noticed this game only uses 6 lines of the 7 segment driver.  (No commas)  so I jumped the dead input and output to the respective unused pins.
Replaced the resistor because why not.
Lasted about five hours before an entire digit on player 2 and 4 disappeared.   :lol
More drama, next post.
jennifer
« Reply #2 on: October 18, 2020, 12:11:36 am »
« Last Edit: April 14, 2021, 11:25:50 pm by jennifer »
« Reply #3 on: October 18, 2020, 12:25:32 am »
It’s one of my favorites, and I’m horrible at it.  This was a rescue out of a puddle of mud in San Antonio over a decade ago.  I got tired of chasing gremlins on the mpu and driver board and bought replacements from pinballpcb.  I’m not entirely happy with what I received or how I’ve been treated post sale, but the boards do work.
That backglass is missing most of the colored ink, so what you’re seeing is a bunch of colored transparencies glued to the back.  Cabinet was missing 90% of the black so I rattle canned it back.  This is a polished turd.  I’m probably in for $1,500 at this point and I’ll never get it back out of it.
Anyway, a reflow on the strobe pins in question and cleaning the edge connector got my missing digit back.
jennifer
« Reply #4 on: October 18, 2020, 12:42:28 am »
« Last Edit: April 14, 2021, 11:26:06 pm by jennifer »
« Reply #5 on: April 02, 2021, 07:11:18 am »
Turned on Firepower last night... and lower left segment is dead...
again....
 :banghead:
Stay tuned?
 :dunno
« Reply #6 on: April 02, 2021, 08:57:20 pm »
Isolated it down to one bad slave display.  Swapped in one from a junk box.  Worked great for four hours and then it smoked one of the master display resistors.  Back to the junk box.
For now I’ve desoldered the problem strobe pin on the slave display.
Owning this machine is an exercise in fun and misery.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: April 03, 2021, 01:33:16 am »
A lot of times a bad display panel (internally shorted) will take out those resistors. Sometimes, modifying the high voltage section of the power supply board to drop the +100 and -100 volts down to 91 volts helps considerably in keeping the resistors from burning up on the master display board.
« Reply #8 on: April 03, 2021, 10:21:47 am »
The complete LED replacement kit is about $110 shipped from Wolffpack.  I need to just go ahead and bite the bullet.
jennifer
« Reply #9 on: April 03, 2021, 12:43:59 pm »
« Last Edit: April 14, 2021, 11:26:19 pm by jennifer »
