Author Topic: Red ball top for p360s  (Read 1993 times)
BombJack
  • Last login:May 31, 2004, 05:50:59 am
  • I'm a eye doc!
« on: January 27, 2004, 09:12:07 am »
I am looking for replacement handles for my p360s. Will these handles from arcadeshop fit?
http://www.arcadeshop.com/pics/robotron-long-shaft-set.jpg
shmokes
  • Don't tread on me.
    • Jake Moses
Re:Red ball top for p360s
« Reply #1 on: January 27, 2004, 09:57:58 am »
yes
That's what Oscar uses -- the ball tops with the long, 4 in. shaft made for Robotron.  He wrote it all up a long time ago.
Best Kid iPad Apps
Grasshopper
« Reply #2 on: January 27, 2004, 03:40:10 pm »
Any handle that can be fitted to the Wico leaf bases will also work with the Perfect 360.
rdagger
« Reply #3 on: January 27, 2004, 08:47:41 pm »
They fit but they may not be long enough.  I converted a p360 to ball top using a Wico handle.  The handle was about 1/16" to short to get the C-clip on.  I had to sand down the actuator to make it work.  However, it works well.  You could probably also shorten the metal spacer.
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #4 on: January 27, 2004, 10:11:55 pm »
That's curious.  I've only converted (4) Happ P360's with Wico handles so far, but all of them fit perfect without doing anything.  The spring couldn't compress enough to put the retaining ring on yours?  IIRC, on mine the spring compresses ever so slightly more than with the original Happ handles, but not enough to notice.
Are those repro handles, or original Wico's?  If they are repro's, perhaps the groove isn't in exactly the same place as the originals.  Just a thought???
OSCAR
    • Oscar Controls
« Reply #5 on: January 27, 2004, 10:21:55 pm »
I just re-read your post and maybe that's the problem.  Don't use the metal spacer at all with a Wico handle.  See reply #14 in this thread:  http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=6294
