Author Topic: missing green on lcd monitor  (Read 2113 times)
64bitmatthew
  • Last login:July 19, 2017, 12:11:04 pm
« on: May 15, 2017, 11:26:17 pm »
Hey folks,
I recently installed an lcd screen into my hangtime cabinet.  I used an ega/cga to vga converter board.  It has picture, but after playing with all the settings on both the lcd and the converter board, I'm pretty sure the green color signal is not coming in at all.  I know people have had problems with the color settings with ega/cga/vga boards before, but I tried changing every setting, and I was never able to get any green color at all.  I also have no yellow, and the white has a purplish tint to it.
With this in mind, how do I go about tracing the problem?  This might sound very dumb, but would the green cable come in carry a certain level of voltage?  So that I could test it with a voltmeter to see if it was coming through at a similar level as the red and the blue?
I lent my voltmeter out to a friend, but am getting it back tomorrow, so can test things then.  Just wanted to see if that was the next step, or if I should be testing things a different way.
Also, I tested the signal off the converter board with two different monitors and two different vga cords, so I think I can eliminate those off the possibility list.
Thanks in advance for any help/advice you might be able to offer.
64bitmatthew
Re: missing green on lcd monitor
« Reply #1 on: May 15, 2017, 11:47:03 pm »
I just disconnected the red, and the screen only displays black and blue. When I tried to hook up red through green, I got yellow. But green through red resulted in nothing. So that leads me to believe I'm not getting any green signal.
« Last Edit: May 15, 2017, 11:55:49 pm by 64bitmatthew »
64bitmatthew
« Reply #2 on: May 16, 2017, 12:16:54 am »
Never mind, I got it going. Was simply a dirty jamma to board connection. Doh!
